Shop the Holiday Gift Guide
Error Codes
Matt Zieminski and 2 contributors
Last updated on
Safety First! Before you begin, remember that safety is paramount. Always unplug your washing machine before attempting any repairs or diagnostics. This precaution is crucial to prevent electric shock or damage to your appliance.
Understanding Your Washing Machine: This guide covers various problems, from water inlet problems to drying challenges or unexpected leaks. We’ve broken down each problem into three key sections:
  1. Problem: Identifies the specific issue you're experiencing.
  2. Why It Happens: Provides a brief explanation of potential causes.
  3. How to Fix: Offers step-by-step solutions to resolve the issue.
Ready to Solve the Issue? With this guide in hand, you're well-equipped to handle washing machine issues with ease. Let’s dive in and get your washing machine running smoothly again!
Causes
Why It Happens?
The washer isn't getting enough water or the water level isn't changing as expected.
How to Fix
  1. Ensure your water supply is turned on and the hose isn't kinked.
  2. Restart the washer by turning it off and on.
2
Why It Happens?
The washer is having trouble draining water.
How to Fix
  1. Check for blockages in the drain hose and filter.
  2. Restart your washer to reset the system.
3
Why It Happens?
Too much water in the washer.
How to Fix
  1. Reduce the load size and ensure the detergent amount is correct.
  2. Reset the washer by turning it off and on.
4
Why It Happens?
The laundry load is uneven or too small.
How to Fix
  1. Adjust the load to balance it, or add more items.
  2. Reset the washer to clear the error.
5
Why It Happens?
The water temperature is changing unexpectedly.
How to Fix
  1. Check the water heater settings
6
Why It Happens?
An issue with the water level sensor, or there is a leakage in the washer.
7
Why It Happens?
The water temperature is not suitable for the selected cycle.
8
Why It Happens?
A problem with the temperature sensor.
9
Why It Happens?
The motor is having difficulty moving. Check your manual to determine whether code 3E is a voltage error or motor error.
10
Why It Happens?
The voltage supply is invalid. Check your manual to determine whether code 3E is a voltage error or motor error.
Describe your problem in your own words
View statistics:
Past 24 Hours:14
Past 7 Days:153
Past 30 Days:609
All Time:8,944
