Roccat Vulcan II Mini Air Keys Are Unresponsive
If pressing the keys on your keyboard doesn't register on the screen of the connected device, follow this troubleshooting guide for potential solutions.
Causes
Dirt, dust, and debris can build up under the keys over time, causing the keys to become unresponsive and requiring them to be cleaned or replaced. Carefully clean the keys with compressed air to remove dust or debris. A cleaning guide can be found at Roccat Vulcan II Mini Air Keycap Replacement
2
The most obvious sign is that pressing the key does not produce any letter, number, or symbol on the screen. Sometimes, simply taking the keycap off and putting it back on can re-establish a connection. If not, the switch underneath the keycap no longer works and needs to be replaced. A switch replacement guide can be found here.
3
The battery has run out of power and is no longer powering the device. Use the chord to plug in the device and charge it. If after charging the battery for a while and the device still doesn't have power without the chord, the battery may need to be replaced. A battery replacement guide can be found at Roccat Vulcan II Mini Air Battery Replacement
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:2
Past 30 Days:19
All Time:401
