Shop the Holiday Gift Guide
Guides
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Background
Roccat, a subsidiary of Turtle Beach, originally released the Vulcan II Mini Air on July 20, 2023, as a part of its Vulcan II series that was meant to succeed the original Vulcan series. As a wireless version of the Vulcan II Mini, it was the first wireless gaming keyboard for Roccat. It features Titan II Optical Switches, which offer fast and responsive typing and ultra-low latency for gaming. Its wireless connectivity is powered by Bluetooth 5.2, ROCCAT’s 2.4 GHz Stellar Wireless connector, and it also includes a USB-C wired mode. It has a Mini 65% form factor.
Identification
This device is easily identifiable by its compact size. The Roccat brand name is printed on the top center of the keyboard's front, as well as on the space bar, where "Vulcan" appears in smaller font just below it. Additionally, a label on the back of the keyboard displays the manufacturer, model name, and number.
Technical Specifications
  • Keyboard dimensions
    • Inches (length, width, height): 12.8 x 4.9 x 1.3
    • Centimeters (length, width, height): 32.5 x 12.4 x 3.3
  • Keyboard weight
    • 576g without cable
    • 617g with cable
  • Polling Rate
    • 1000Hz
  • Anti-Ghosting
    • Yes
  • Key rollover
    • N-Key
  • Keyboard size
    • 65%
  • Battery life
    • RGB off: 240h
    • RGB on: 31h
  • Battery charge time
    • 6 hours, charging via cable (depending on power source)
  • Connection options
    • 2.4 GHz stellar wireless via USB-A transmitter
    • Bluetooth 5.2
    • USB-A cable (required for Firmware updates)
  • Wireless range (without any RF interference)
    • In feet: 30
    • In meters: 10
  • Bluetooth range (without any RF interference)
    • In feet: 30
    • In meters: 10
  • Switch type
    • Optical
  • Switch lifecycle
    • 200 Million presses
  • Available switches
    • Linear
    • Tactile
  • Key travel distance
    • Linear 3.6mm
    • Tactile 3.6mm
  • Actuation point
    • Linear 1.4mm
    • Tactile 1.8mm
  • Software support
    • ROCCAT Swarm (supported under Windows 7 upwards)
  • Compatibility
    • Windows PC (full support for Windows 7 or higher through Swarm)
    • Mac OS (no advanced features or software support)
    • Linux (no advanced features or software support)
    • Consoles (Xbox One, Xbox series X, PS4/PS5) only via transmitter/cable, requires game support
  • Illumination type/LEDs
    • Per key + 29 Smart Key LEDs
  • RGB range
    • 16.8 million colors
  • Foldable feet
    • Double height
  • Keycap material
    • ABS
  • Case material
    • Plastic
  • Top plate material
    • Aluminum anodized sanded
  • Cable length
    • 1.8m / 5.9ft
  • Cable type
    • Braided, USB-A to USB-C
  • Connection type
    • USB 2.0
Additional Information
Author
with
Elizabeth
226 Reputation
1 Guide authored
UMass Dartmouth, Team 3-3, Santin Fall 2024 Member of UMass Dartmouth, Team 3-3, Santin Fall 2024
UMASSD-SANTIN-F24S3G3
4 Members
48 Guides authored
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 56
All Time: 1,902
