Causes
A faulty battery could cause the RetroMini Miyoo Mini Plus to short circuit. Therefore not allowing enough power to run the device.
- Verify that the battery to the RetroMini Miyoo Mini Plus is partially charged.
- Plug in the charger to the RetroMini Miyoo Mini Plus for approximately 15-20 minutes.
- If the battery appears to be damaged then you may need to replace the battery. Check this repair guide here.
RetroMini Miyoo Mini Plus Battery Replacement
- 2 - 5 minutesEasy
Sometimes the RetroMini Miyoo Mini Plus will freeze, giving the appearance of it turning off.
- Press and hold the power button on the RetroMini Miyoo Mini Plus until the device turns off.
- Check to see if there is a "Loading Screen" appearing when powered back on.
- Try pushing in both the Menu button and the Power button. This will revert to the main menu.
Sometimes a faulty SD Card will cause the device to power on and show only a black screen.
- Try reformatting the original SD Card incase there are corrupt files.
- If reformatting fails. You can replace the SD Card with a similar model. If a new SD Card is needed then make sure you install Onion OS onto the new card.
Describe your problem in your own words
View statistics:
Past 24 Hours:2
Past 7 Days:8
Past 30 Days:56
All Time:1,381
