Shop the Holiday Gift Guide
RetroMini Miyoo Mini Plus Battery Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
11
Past 7 Days:
59
Past 30 Days:
310
All Time:
3,596
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If your RetroMini Miyoo Mini Plus seems to not hold a charge or turns off frequently. If so here is a guide to replacing the battery. While the guide can be done with only your hands, it may be easier with a small flat head screwdriver or IFixit Opening Tool.
Tools
    1. RetroMini Miyoo Mini Plus Battery Replacement, Battery: step 1, image 1 of 2 RetroMini Miyoo Mini Plus Battery Replacement, Battery: step 1, image 2 of 2
      • Lay the device face down on a flat surface.
      • You may want to lay the device on a towel or other soft surface to avoid scratching the screen.
      Ask FixBot
    2. RetroMini Miyoo Mini Plus Battery Replacement: step 2, image 1 of 2 RetroMini Miyoo Mini Plus Battery Replacement: step 2, image 2 of 2
      • Use your fingernail to push in the battery compartment tab.
      • Lift the cover up to expose the battery.
      Ask FixBot
    3. RetroMini Miyoo Mini Plus Battery Replacement: step 3, image 1 of 1
      • Use an opening tool to gently lift the the battery from its compartment.
      • Gently pull the battery out and set the battery next to the system, with care not to strain the attached wire.
      Ask FixBot
    4. RetroMini Miyoo Mini Plus Battery Replacement: step 4, image 1 of 2 RetroMini Miyoo Mini Plus Battery Replacement: step 4, image 2 of 2
      • Pinch the white battery connector and pull it directly out of its socket.
      • Completely remove the battery.
      Ask FixBot
    5. RetroMini Miyoo Mini Plus Battery Replacement: step 5, image 1 of 2 RetroMini Miyoo Mini Plus Battery Replacement: step 5, image 2 of 2
      • When you have the new battery, put the new battery wire into the connecter.
      • Place the battery back into the empty space with the wire at the bottom of the battery.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Steam Deck answers community for help.
Author
with
Kaden
599 Reputation
4 Guides authored
1 Guide Comment
Does anyone know where to get these batteries? Or perhaps the specs of the Miyoo Mini Plus battery such as dimensions (mine is a bit obese right now) and connector type?
Arend Hamming - Reply Share
Past 24 Hours: 11
Past 7 Days: 59
Past 30 Days: 310
All Time: 3,596
