Shop the Holiday Gift Guide
Overheating
Jade Weiss and 1 contributor
Last updated on
Causes
Although the back plating on the Nest Cam is meant for heat protection and absorption, Nest Cam may still overheat. If you feel your Nest Cam is too hot, unplug your Nest cam for a minute or so and then plug it back in. It is possible it just needs a rest.
2
Your Nest Cam may be in a spot that makes it unable to breathe. If you have your Nest Cam mounted in or on a material that does not absorb heat very well or blocks airflow your Nest Cam may even shut off.
Ensure that your Nest Cam is in a well ventilated area and not in direct sunlight. Nest Cam is only to be used indoors so if your Nest Cam is monitoring from the outside, you may want to rethink your placement options.
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:15
Past 30 Days:59
All Time:1,206
