Shop the Holiday Gift Guide
Will Not Charge
Isaac Loma and 2 contributors
Last updated on
If your JBL Grip does not charge or power on, the issue may be related to the charging cable, port, battery, or internal board. Follow this page for solutions.
Causes
  • Charging accessories may be defective.
Solution:
  • Try a different USB cable.
  • Try a different wall adapter.
  • Plug into a different power outlet.
2
  • Dust, lint, or debris inside the charging port can block the connection.
Solution:
  • Inspect the port using a flashlight.
  • Gently clean with a non-metallic tool (like a toothpick).
  • Avoid inserting sharp metal objects.
If the port is physically damaged, replacement may be required.
JBL Grip Charging Port Replacement
3
  • Lithium-ion batteries degrade over time and may fail completely.
Signs:
  • Device only works when plugged in
  • No LED charging indicator
  • Device powers off immediately after unplugging
Solution:
  • Replace the battery.
Battery Replacement Guide
4
  • If the device is charging but shows no indicator lights, the LED board may be damaged.
Solution:
  • Inspect and replace the LED board if necessary.
Required tools list:
Phillips head screwdriver, etc.
Safety warnings (battery puncture risk): Don't attempt to repair while charging. If soldering, be aware of high-temperature components.
Describe your problem in your own words
View statistics:
Past 24 Hours:3
Past 7 Days:20
Past 30 Days:107
All Time:576
