JBL Grip Battery Replacement
    1. JBL Grip Battery Replacement, Case: step 1, image 1 of 2 JBL Grip Battery Replacement, Case: step 1, image 2 of 2
      • Slide the Jimmy along the seam to separate the case.
      • Caution: Do not bend or puncture membrane.
      Ask FixBot
    2. JBL Grip Battery Replacement: step 2, image 1 of 2 JBL Grip Battery Replacement: step 2, image 2 of 2
      • Unlatch the membrane from the rest of body.
      Ask FixBot
    1. JBL Grip Battery Replacement, Charging Port Panel: step 3, image 1 of 2 JBL Grip Battery Replacement, Charging Port Panel: step 3, image 2 of 2
      • Remove the eight 6mm screws securing the panel with a Phillips #2 screwdriver.
      Ask FixBot
    2. JBL Grip Battery Replacement: step 4, image 1 of 3 JBL Grip Battery Replacement: step 4, image 2 of 3 JBL Grip Battery Replacement: step 4, image 3 of 3
      • Flip up the black latches securing the two blue cables connected to the panel.
      • Caution: Do not pull the cables by force. Ensure the latches are fully lifted.
      Ask FixBot
    1. JBL Grip Battery Replacement, Battery: step 5, image 1 of 2 JBL Grip Battery Replacement, Battery: step 5, image 2 of 2
      • Carefully pull the detached end of the battery from the chassis.
      • Be sure not to pull too hard; the cables are fragile.
      Ask FixBot
    2. JBL Grip Battery Replacement: step 6, image 1 of 2 JBL Grip Battery Replacement: step 6, image 2 of 2
      • Unplug the wires from their socket.
      • Be gentle; these parts are fragile.
      • Once the wire is unplugged, safely remove it.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 27
Past 30 Days: 127
All Time: 463
