Causes
If all software, drivers, and settings are correct and the laptop still cannot connect, the wireless adapter hardware itself may be failing or disconnected.
Check the wireless adapter in Device Manager → Network adapters; if it shows errors or fails to start, this may indicate a fault.
Test with an external USB Wi-Fi adapter. If this connects successfully, the internal WLAN module likely needs replacement.
Inspect antenna cables and connectors if you’re comfortable opening the laptop.
Follow the WLAN replacement guide to access and replace the internal Wi-Fi module.
HP ProBook 640 G5 WLAN Module Replacement
- 15 - 20 minutesEasy
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:5
Past 30 Days:25
All Time:122
