Up to 20% off select tools
HP Chromebook 14 G4 Screen Not Lighting Up
Christian Leaman and 1 contributor
Last updated on Causes
Hard reset your Chromebook basically flushes its RAM and brings it back to the starting point to start all processes again.
- Locate the Refresh key and the power button on your Chromebook.
- Press them together.
- This should hard reset your Chromebook.
- Try turning it on.
Follow the next steps if the method does not resolve this issue.
If you have external devices such as a mouse, keyboard, or webcam connected to your Chromebook, they could be the cause of it not turning on.
- Locate the refresh key and power button on your Chromebook.
- This is because peripherals come with firmware, particularly gaming peripherals which have their designated software, that can interfere with the boot up process.
- Remove all external devices connected and try turning it on again.
If it works, you'll have to work without peripherals.
Related Problems
HP Chromebook 14 G4
3 problems · View all
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:5
Past 30 Days:21
All Time:342
