Shop the Holiday Gift Guide
Freezing Randomly
Christian Leaman and 2 contributors
Last updated on
Is your HP Chromebook 14 G4 freezing randomly when in use? Use this troubleshooting guide to help diagnose why.
Causes
Chromebook could be out of date.
  • First, clear all tabs and apps running and restart your Chromebook.
  • After your Chromebook restarts, open your settings and search "About Chrome OS" in the search bar then click on "Check for Updates."
  • Click on any available updates and begin running them. Keep your Chromebook plugged in to avoid it powering off in the middle of an update.
Follow the next steps if the method does not resolve this issue.
2
Simple reset could fix freezing.
  • To reset your Chromebook, click on the time icon in the bottom-right corner and select the power icon to turn off your Chromebook.
  • Choose the option "Restart" and the Chromebook will shut down.
  • After the Chromebook shuts off completely, power it back on and sign back in.
If it works, skip next steps
3
Chromebook steps to Powerwash:
  • Make sure your Chromebook is charged or plugged in to avoid interruptions.
  • Next, ensure sure all of your important files and data are saved to an external storage device or to your Google Drive and sign out of your Chromebook by clicking on your profile picture in the bottom-right corner of the screen and selecting "Sign out."
  • Access the Powerwash menu on the sign-in screen by pressing Ctrl + Alt + Shift + R together. Select "Powerwash" after doing so it will prompt a question asking if you want to reset your device, click on "Powerwash" and then "Continue."
  • After completing these steps, all you should have to do is wait for your Chromebook to reset.
You can use HP's technical expertise for assistance or repair locally.
4
If none of the troubleshooting steps helped you resolve these issues, the problem can be severe, such as faulty RAM or a damaged motherboard. Contact HP Support. They can assist.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:5
Past 30 Days:25
All Time:351
