Garmin Edge 530 Black Screen
If you're having issues with your Garmin Edge 530 displaying a black screen or otherwise not appearing to turn on despite being charged, use the solutions below to get your device back on track.
Causes
Look for any visible defects to the screen, any deep scratches, or obvious breaks. If the screen is in need of repair, follow Garmin Edge 530 LCD Screen Display Replacement to find step-by-step instructions.
2
Sometimes the internal parts of the Garmin Edge 530 that work to make up the LCD screen display of the device will break or go bad. If this is the case, there should be no visible defects in the screen, the device will turn on and fully charge, but the screen will remain dark or blank. Make sure that the screen is not in need of repair before troubleshooting the internal display. If the display is no longer functional, follow the Garmin Edge 530 LCD Screen Display Replacement to replace the faulty part.
3
There may be issues with the motherboard connecting to the internal LCD screen display or is faulty over time. If you notice the screen is turning on and lighting up, but is returning a blank white screen at a dimmer brightness, while the screen has no defects and is able to charge, the issue may lie with the motherboard. Make sure that the internal LCD screen display is not in need of repair before troubleshooting the motherboard. If the motherboard is in need of replacement, follow the Garmin Edge 530 Motherboard Replacement for step-by-step instructions.
Describe your problem in your own words
View statistics:
Past 24 Hours:2
Past 7 Days:13
Past 30 Days:65
All Time:1,806
