Garmin Dash Cam 35 Buttons are Unresponsive
If your Garmin Dash Cam 35 is not turning on when holding the power button, follow these steps to troubleshoot the issue.
Causes
  • Hold down the power button for 20 seconds to determine if the device will respond.
  • Try pressing other buttons to check whether the issue is isolated to a single button or all the buttons.
2
  • Plug the device into a direct source of power rather than a vehicle power outlet.
    • Try two different cables to this source of power.
  • Try another independent source of power, such as a computer or wall outlet.
    • Try two different cables for this source as well.
3
  • Look inside the port for dust, debris, or corrosion that may prevent proper contact,
  • Visually inspect the port to see if any internal prongs are broken or bent.
4
  • Remove the microSD card and attempt to power the device on without it.
  • Try a different, known working microSD card to rule out card corruption as the cause.
    • Ensure the replacement card meets Garmin's speed and size requirements.
5
  • If any button responds intermittently, attempt a soft reset by holding the power button until the device restarts.
  • If available, use the in-menu reset options to clear any temporary software errors without deleting the recording.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:4
Past 30 Days:20
All Time:180
