Shop the Holiday Gift Guide
Buttons Unresponsive
Sherap Grg and 2 contributors
Last updated on
If the buttons on your Flydigi Apex 4 controller do not respond when pressed, this page offers some solutions.
Causes
The controller fails to register button inputs due to an unstable or interrupted connection.
Cause
If the controller is not securely connected to the device, button inputs may fail to register.
Solution
  • Disconnect the controller from your computer or console.
  • Reconnect the controller securely.
  • If using a wired connection, try a different USB port or cable.
  • If using wireless mode, reconnect the controller through Bluetooth or the wireless adapter.
  • Restart your device and test the buttons again.
2
Outdated or corrupted drivers prevent the controller from communicating properly with the system.
Cause
Outdated or corrupted drivers can prevent the controller from properly communicating with the system, which may result in unresponsive buttons.
Solution
  • Restart your device to refresh the controller connection.
  • Check for available driver or firmware updates for the controller.
  • Install any updates and restart your system.
  • If the problem persists, uninstall and reinstall the controller software.
3
Incorrect mapping or configuration settings cause buttons to perform unintended actions or no action at all.
Cause
Incorrect button mapping or controller configuration settings may prevent buttons from performing their intended actions.
Solution
  • Open the controller configuration software or system controller settings.
  • Check the current button mapping configuration.
  • Reset the button mapping to the default settings.
  • Test the controller in another game or a controller testing application.
4
Foreign particles trapped beneath the buttons block movement or prevent the contacts from registering input.
Cause
Dust, dirt, or debris trapped under the buttons can block proper movement or prevent the button contacts from registering input.
Solution
  • Turn off the controller before cleaning.
  • Use compressed air to blow around the affected buttons.
  • Gently clean the button area using a soft brush or cotton swab.
  • Avoid using metal tools that could damage internal components.
5
If the buttons remain unresponsive after trying these solutions, the internal button mechanisms may need to be replaced. Inspect the controller for internal damage or consider replacing the affected components.
Describe your problem in your own words
View statistics:
Past 24 Hours:5
Past 7 Days:33
Past 30 Days:124
All Time:608
