Causes
Allowing the battery to drain completely on a regular basis can reduce the lifespan of lithium-ion batteries and lead to premature failure.
Solution: Charge the device before the battery reaches 0% and try to keep the battery level between moderate ranges during regular use. After adjusting charging habits, monitor whether battery performance improves.
Using the device on soft surfaces such as beds or couches can block ventilation, causing overheating that damages the battery over time.
Solution: Place the device on a hard, flat surface during use to allow proper airflow. Avoid covering vents and keep the device in a cool environment. If overheating has been frequent, long-term battery capacity may already be reduced.
High screen brightness, multiple open applications or tabs, and active Bluetooth connections can drain the battery more quickly than normal.
Solution: Lower the screen brightness, close unused applications or tabs, and disable Bluetooth when it is not needed. These adjustments can help extend battery life during daily use.
Describe your problem in your own words
