Corsair K65 Plus Wireless Keys Stick
If the keys on your Corsair K65 Plus Wireless are hard to press down or stays down without coming back up after release, this page may have a solution.
Causes
If the key does not operate properly there may be something blocking it. This obstruction may need to be removed to let the key to travel correctly. Refer to the key cap replacement guide to clean the area underneath the stuck key.
2
On the larger keys such as the space bar, shift, enter, and backspace, there are key stabilizers that help to prevent the key from wobbling or tilting when the large keys are pressed off-center. If the stuck key is one of these, the key stabilizer may be faulty or misaligned. For a misaligned stabilizer, refer to the key cap removal guide. For replacement refer to the key stabilizer replacement guide.
3
If the key gets stuck in the pressed position, or does not operate correctly even after cleaning, the key switch may be faulty. Refer to the key switch replacement guide for repair.
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:4
Past 30 Days:15
All Time:103
