CAT S62 Battery Draining Quickly
If your CAT S62 loses battery charge extremely quickly or fails to hold a charge, follow this page for possible solutions.
Causes
Apps running in the background may use a significant amount of battery, which can cause the device's battery to drain quickly.
Method 1: Close recent apps
  1. Tap the square button on the bottom right of the screen.
  2. To close one app, swipe up on its thumbnail.
  3. To close all apps, find an option such as "Clear all" or "Close all," and then tap it.
Method 2: Force stop an app
  1. Go to Settings.
  2. Tap on Apps & notifications.
  3. Tap See all apps.
  4. Scroll down and select the app you want to close.
  5. On the App info page, tap "Force stop" and confirm by tapping "OK".
2
  1. Swipe down from the top of the screen to open the drop-down menu.
  2. Find the brightness slider and swipe left to lower the brightness.
3
  2. Find the Wi-Fi, Bluetooth, or other toggles and tap them to turn them off. The icons should turn from colored to grey.
4
Method 1: Drop-down Menu
  1. Swipe down from the top of the screen to access the quick settings panel.
  2. Tap the battery icon to toggle Battery Saver on.
Method 2: Direct Settings
  1. Go to Settings.
  2. Find the battery tab.
  3. Find the Battery Saver option and tap "Turn On".
5
  1. Open the Settings menu. You can do this from the home screen by swiping up to view all apps, then finding and tapping the "Settings" icon.
  2. Scroll down and select "System".
  3. Tap on "Advanced" in the System menu.
  4. Select "System update".
  5. Tap "Check for update" or wait for the phone to automatically begin searching for available updates.
  6. Follow the on-screen instructions if an update is found.
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:11
Past 30 Days:27
All Time:403
