Asus Chromebook CX1500CKA-AS84F Does Not Power On
If your Asus Chromebook CX1500CKA-AS84F doesn't turn on when the power button is pressed, follow this page for solutions.
Causes
If the power adapter is damaged or not providing enough power, the Chromebook won’t turn on.
If you’re using the original Asus USB-C charger, check that both ends of the adapter are securely seated and that the outlet is functioning.
  1. When the charger is plugged in, the indicator light on the side of the Chromebook should illuminate (orange when charging, green/white when fully charged).
  2. Try plugging the charger into a different outlet or using another compatible charger if available.
  3. If the Chromebook still does not show any charging indicator, the problem may be with the adapter, battery, or charging circuit.
  4. If available, test with another compatible charger. If the Chromebook powers on with a different charger, replace the original adapter.
2
A discharged or failing battery can prevent the Chromebook from powering on.
  1. Leave the charger connected for at least 15–30 minutes before attempting to power on.
  2. If the Chromebook only works when plugged in but shuts off immediately when unplugged, the internal battery is likely failing and needs replacement.
  3. Inspect the battery if possible: if it looks swollen or misshapen, replace it immediately.
How to replace:
Step 1: Remove Bottom Panel
  • Shut down the Chromebook completely.
  • Remove all visible screws on the bottom case.
  • Check under the rubber feet for hidden screws.
  • Use a plastic prying tool to gently separate the bottom cover from the chassis.
Step 2: Disconnect the Battery Cable
  • Locate the battery (large rectangular pack).
  • Find the cable connecting the battery to the motherboard.
  • Use a spudger to carefully disconnect the cable by rocking it side to side.
Step 3: Remove Battery Screws
  • Unscrew all Phillips screws securing the battery to the chassis.
  • Keep the screws in a safe place for reassembly.
Step 4: Remove Battery
  • Lift the battery out from the bottom edge.
  • Be careful not to bend or puncture it.
Step 5: Install New Battery
  • Place the replacement battery into position.
  • Screw it securely into place.
  • Reconnect the battery cable to the motherboard.
Step 6: Reassemble Chromebook
  • Snap the bottom cover back on.
  • Reinsert all screws.
  • Power on the Chromebook to confirm the new battery works.
3
Sometimes ChromeOS may freeze on a black screen, making it seem like the Chromebook won’t power on.
  1. Disconnect all external devices.
  2. Press and hold the power button for 10 seconds to force a shutdown, then press it again to restart.
  3. If the system still does not boot, you may need to perform a ChromeOS recovery using a USB drive.
4
If the power adapter, battery, and display are all functional, but the Chromebook still won’t power on, the problem may lie with the motherboard. The motherboard can be damaged by power surges, liquid spills, overheating, or physical impact. When this happens, the Chromebook may not power on at all.
  1. Inspect the motherboard for visible damage or burnt components.
  2. If no other troubleshooting steps work, replacing the motherboard may be necessary.
How to replace:
Step 1: Remove Back Panel
  • Turn the laptop upside down.
  • Unscrew 10 screws around the edge of the back panel:
  • Use a plastic prying tool to gently remove the back panel.
Step 2: Remove Battery
  • Unscrew four screws securing the battery.
  • Unclip the battery wire connectors on the top and right sides.
  • Lift the battery out of the device.
Step 3: Remove Optical Drive
  • Lift the sticker that connects the optical drive to the motherboard.
  • Unscrew the single screw holding the optical drive.
  • Gently slide the drive out, watching for surrounding wires.
Step 4: Remove Cooling Fan
  • Unscrew the screws securing the fan.
  • Disconnect the 4-color wire and the black cable.
  • Carefully move the surrounding wires away.
  • Keep the fan if it’s still in good working condition.
Step 5: Remove Motherboard Screws
  • Unscrew seven screws around the motherboard edges.
Step 6: Disconnect Cables
  • Disconnect all remaining cables from the motherboard.
  • Open the small white adjustable latches to release ribbon cables.
Step 7: Remove Motherboard
  • Lift the motherboard gently out of the laptop.
Describe your problem in your own words
View statistics:
Past 24 Hours:2
Past 7 Days:8
Past 30 Days:44
All Time:299
