Causes
- Forget the problematic Wi-Fi network by going to Settings → Wi-Fi → Saved Networks → [Network Name] → Forget.
- Reconnect by selecting the same network and entering the password again.
- For Bluetooth, go to Settings → Bluetooth → Paired Devices, unpair the device, and pair it again for a fresh connection.
- Turn on Airplane Mode for about 10 seconds, then turn it off to refresh all network connections.
- Move closer to your Wi-Fi router or ensure no large metal objects or microwaves are causing interference.
- Try connecting to another Wi-Fi network or Bluetooth device to confirm if the issue is specific to one connection.
- If the problem continues, perform a Network Settings Reset by going to Settings → Device → Reset → Network Settings Reset.
- This will clear all saved Wi-Fi and Bluetooth connections, giving you a clean slate to reconnect.
- If the issue still persists, contact Alcatel’s technical support or your carrier for further assistance.
Describe your problem in your own words
View statistics:
Past 24 Hours:0
Past 7 Days:2
Past 30 Days:19
All Time:186
