Shop the Holiday Gift Guide
Won't Turn On
The Basics
Before attempting any significant repairs for your device, check the following. TESTING
- Ensure your Chromebook's charging cable is correctly seated in the charging port. To enable proper charging, a complete circuit must be established between the charger, the Chromebook, and the power source.
- Attempt a hard reset of your Chromebook. Press and hold the power button for at least 10 seconds to discharge any built-up power and possibly resolve software glitches. Then, try powering on your Chromebook again.
- Ensure your charging port is clean. Dust or debris can sometimes accumulate in the charging port, preventing the proper connection. Use a soft brush or compressed air to clean the charging port gently.
Causes
If your Chromebook does not power on or show signs of life, the issue may be related to the battery. Follow these steps to troubleshoot battery-related problems.
- Check Battery Level: Connect your Chromebook to the charger and wait at least 15 minutes. Then, see if the charging indicator light shows the device is charging. If not, the battery might be completely drained or faulty.
- Try a Different Charger: Use a different charger that's known to work with your Chromebook model. If the device starts charging with the new charger, the original might be defective.
- Remove External Peripherals: Disconnect external devices such as USB drives, headphones, or monitors. Sometimes, a faulty peripheral can prevent the Chromebook from powering on.
- Reset the Battery: Some Acer Chromebooks have a small pinhole reset button on the bottom or side of the device. Insert a paperclip or a similar tool into the pinhole and press gently to reset the battery. Afterward, try powering on the Chromebook.
If the Chromebook still does not power on, proceed to the next section.
Sometimes, it's not the Chromebook but the malfunctioning display. Check with an external monitor to see if the Chromebook is working but not displaying anything.
If your Chromebook is on, but the screen remains dark, check out our Acer Chromebook Black Screen page instead.
Your Chromebook could have encountered an issue during a ChromeOS update, causing it to appear off or display a black screen. This is due to a lack of proper instructions from the software to boot up. To resolve this, you can restore ChromeOS by following this guide or the instructions below.
Note: Performing a ChromeOS recovery will erase all the data stored directly on the Chromebook.
- Go to the Chromebook Recovery Utility website using a separate device.
- Install the Chromebook Recovery Utility.
- Prepare a USB recovery drive: Connect a USB flash drive (8GB minimum) to the computer and launch the Chromebook Recovery Utility. Select your Chromebook model from the list and click Continue. The utility will download the necessary recovery image to the flash drive.
- To recover ChromeOS on your Chromebook, Insert the USB drive into the affected Chromebook. Please turn it off, hold the Esc and Refresh (F3) keys, and press power to start the recovery.
- Follow the on-screen instructions to complete the recovery process. Your Chromebook will be restored to its original factory settings with a fresh installation of ChromeOS.
If the issue persists even after restoring ChromeOS, it may indicate a hardware problem. In such cases, continue to the next section.
Suppose your Acer Chromebook displays a black screen even after following the troubleshooting steps mentioned earlier. In that case, there is a high likelihood of a problem with the motherboard or the surrounding components.
- Remove any accumulated dust or debris from inside the device for proper airflow.
- Ensure that your device's CPU is adequately cooled. Specific Acer Chromebook models, such as the C712 Series, have encountered cooling fan failure caused by disconnected ribbon cables. If you have recently reinstalled your heatsink, double-check that wires are securely attached and that thermal paste has been appropriately applied.
- Reset your device's BIOS Settings by uninstalling and reinstalling the CMOS battery. This clears any potential conflicts or misconfigurations.
- Verify that the RAM module is installed correctly and functioning properly. If it is not properly seated, try reinserting or replacing it.
- Perform a thorough visual inspection of the motherboard for any signs of burns or damaged components. If you observe any visible damage, such as burns or parts that appear to be physically damaged, the motherboard likely needs to be replaced.
About the Author
With a passion for tech repair and over six years of hands-on experience, I’ve worked extensively on laptops, from MacBooks to Acer Chromebooks, while diving into game console hardware repairs for Xbox, PlayStation, and Nintendo Switch controllers. My career began with maintaining Point of Sale systems in a major theme park, where I developed a keen eye for diagnosing hardware issues. Now, I apply my skills in an educational setting, tackling everything from computer repairs for students and teachers to network troubleshooting. I hold Network Administration, Cybersecurity certifications, and more, backed by a Bachelor's in Computer Science.
You're seeing solutions for Acer Chromebook. Select your model to find parts for your device.
Related Problems
Describe your problem in your own words
