Shop the Holiday Gift Guide
Lines on Screen
The Basics
It is often easy to forget the troubleshooting basics during times of frustration. Before attempting any significant repairs for your device, check the following:
- Restart your Chromebook. Restarting your device can sometimes fix temporary glitches or clear out any temporary files that might cause issues. You can restart your Chromebook by either clicking on the clock in the bottom-right corner of the screen and choosing the Restart option or pressing the Ctrl, Shift, and Refresh keys simultaneously.
- Adjust your Chromebook's screen position. By gently adjusting the position of your Chromebook's screen, we can see if a loose connection or misalignment causes the issue. If the lines change or disappear, it is likely an issue caused by the connection.
If the lines on the screen persist after the above steps, connect an external display to your device. If the lines are visible on the external display, this could indicate an issue with the operating system or your device's settings.
If the lines are not visible, your Chromebook's display may have been damaged.
Causes
ChromeOS might be experiencing issues with the operating system, causing issues with how content appears on your screen. You should check to see if an update is available for your Chromebook. You can check what version of Chrome OS your device is running by following these steps.
- Click on the clock in the bottom-right corner of the screen.
- Select the gear icon to open the Settings menu.
- Scroll down and click on About Chrome OS.
- Click on Check for updates and let the system update if any updates are available.
- Restart your Chromebook and check if the lines on the screen persist.
If your display settings have been adjusted recently, this could cause an issue with lines appearing on your screen. Adjust each of the settings below, and see if the lines on your screen change.
- Brightness: Adjust the display's brightness to see if it affects the appearance of the lines. Sometimes, extreme brightness settings might reveal or hide certain visual artifacts.
- Screen Resolution: Experiment with different screen resolutions to see if the lines are affected. Lower resolutions might result in a less detailed display, but it can help isolate potential issues.
- Color Settings: Some display issues might be related to color calibration or settings. You can try adjusting color temperature, contrast, and saturation to see if it makes any difference.
- Display Orientation: In the settings of some Chromebooks, you can change the display orientation (landscape, portrait). This might help you identify if the lines are specific to a particular orientation.
- Night Light or Blue Light Filter: If your Chromebook has a night light or blue light filter feature, try enabling or disabling it to see if it affects the appearance of the lines.
You can also Powerwash your device or use a ChromeOS Recovery USB Drive to factory reset your device.
Note: This will wipe any data stored on the Chromebook and will factory reset the device. Be sure to back up any data that you want to keep onto an external storage device, or to Google Drive.
If any of the above tricks cannot resolve the issue with your Chromebook, then there is a good likelihood that your screen or other component might be physically damaged. Try these simple steps to resolve the issue.
- Inspect your display for any physical damage. This will include any large or tiny fractures in the display. If the screen is damaged, the best solution is to replace it. Use the appropriate guide for your specific Chromebook.
- Perform a visual inspection of the display cable. If there is no visible damage to the screen, or if replacing the LCD panel has not resolved the issue, then conduct a thorough examination of the display cable and its connections. Check both the end of the display and the point where the display cable connects to the Motherboard. Look for any signs of damage, such as burns or indications of liquid damage.
If your Chromebook still has lines on the display, continue to the last section.
If your device's display still shows lines, there is most likely an issue with its Motherboard.
- Reset your device's BIOS Settings. To reset your Motherboard's BIOS settings, you can try uninstalling and then reinstalling the CMOS battery. By doing so, any stored settings or configurations that may have become corrupted will be cleared, and the system will start with default settings. This helps eliminate potential conflicts or misconfigurations that could be causing the issue you're experiencing.
- Verify that the RAM modules are installed correctly and functioning properly. If the RAM module is not properly seated, it can result in display issues. Try re-inserting the RAM module, ensuring it is securely in place. Alternatively, you can consider replacing the RAM module with the same type to eliminate any potential RAM-related problems.
- Perform a thorough visual inspection of the Motherboard for any signs of burns or damaged components. If you observe any visible damage, such as burns or components that appear to be physically damaged, the Motherboard likely needs to be replaced. Use the appropriate guide for your specific Chromebook.
About the Author
With a passion for tech repair and over six years of hands-on experience, I’ve worked extensively on laptops, from MacBooks to Acer Chromebooks, while diving into game console hardware repairs for Xbox, PlayStation, and Nintendo Switch controllers. My career began with maintaining Point of Sale systems in a major theme park, where I developed a keen eye for diagnosing hardware issues. Now, I apply my skills in an educational setting, tackling everything from computer repairs for students and teachers to network troubleshooting. I hold Network Administration, Cybersecurity certifications, and more, backed by a Bachelor's in Computer Science.
You're seeing solutions for Acer Chromebook. Select your model to find parts for your device.
Related Problems
Describe your problem in your own words
