Causes
Try resetting your computer, sometimes a simple reset is all that is needed to fix your keyboard. To do this you can:
- Turn off the Chromebook by pressing and holding the [POWER] button until the device powers down, then turn it back on again with the same button.
Perform a hard reset on your Chromebook's hardware, this will reset the connection of your keyboard to your Chromebook. To do this you can:
- Power off the Chromebook (Press and hold the power button for at least 4 seconds to force shut down)
- Press and hold the [Refresh button], then click the [Power button] to power on.
- Release the [Refresh button] until the Chromebook restarts.
Use a "Guest Account" to reset settings on your keyboard, you can do this by:
- Sign out of your account and try using the keyboard as a guest, to sign out click the [Status Bar] located at the bottom right of the screen, then click “Sign out”.
- Click [Browse as Guest] at the bottom. If the keys work, you can try deleting and re-adding your account.
These errors are generally related to either your drivers or conflicting software, you can use the keyboard troubleshooter to detect and resolve problems. To do this, you can:
- Type and search Troubleshoot settings in the Windows search bar
- Click Open
- Select Keyboard in the troubleshoot window
- Click Run the troubleshooter
- Follow the on-screen prompts
If the keyboard has failed, you can try resetting your Chromebook to factory settings. To do this, you can:
- Sign out of your Chromebook
- Press and hold Ctrl + Alt + Shift + r
- Select Restart
- Select "Powerwash" in the box that appears
- Follow the steps and sign in with your Google Account
If you're still having trouble, you can contact ASUS customer service for more information.
Describe your problem in your own words
