Causes
First, ensure you have the correct battery pack, such as the NP-F330/F550 battery pack, and not one such as the "InfoLITHIUM” battery pack. One of the most common causes of a SONY MVC-FD200 not powering on is a drained battery. If the SONY MVC-FD200 has not been used for a while, the battery may have discharged to the point where it doesn’t have enough power to turn the camera on.
- First, you want to ensure that the battery is properly inserted into the SONY MVC-FD200
- Next, you want to wait for about 30 minutes to see an indicator light or the SONY MVC-FD200 show that charging is in progress.
- If this didn't help, you could always try another battery to determine whether the battery was the issue.
Over time, rechargeable batteries lose their ability to hold a charge, especially if they have been frequently used or left unused for long periods. If the battery is more than a couple of years old or has been exposed to extreme conditions (like high heat or freezing temperatures), it could have failed.
- Make sure to inspect the battery for any damage, swelling, or leakage. If the battery shows signs of damage, replacing the battery may be necessary. If the battery is damaged, it should be replaced immediately in order to get proper functionality.
- Make sure when purchasing another battery, if is a new SONY compatible battery, and avoid using high-quality third-party alternatives only genuine SONY batteries to avoid similar problems in the future.
The issue isn’t always with the battery itself but with the SONY MVC-FD200 battery contacts. If the contacts inside the SONY MVC-FD200 battery compartment are dirty, corroded, or not making proper contact with the battery, the SONY MVC-FD200 may fail to power on.
- First, you want to power off the SONY MVC-FD200 and remove the battery. Also, inspect the battery contacts inside the SONY MVC-FD200 battery compartment to check for dirt, corrosion, or anything preventing proper contacts
- Clean the contacts using a soft cloth or even cotton swabs with rubbing alcohol. Be cautious about damaging the contacts or leaving behind any cotton fibers.
If the contacts appear heavily corroded or damaged, it may require professional repair or replacement of the battery compartments due to the damage. If you are unsure of the cleaning process, consider having a professional inspect and clean the SONY MVC-FD200.
If the battery appears fine and the contacts are clean, the issue might be with the camera’s power supply. The internal circuitry that powers the camera could be malfunctioning, preventing the camera from turning on.
- First, try and power the SONY MVC-FD200 while it is connected to an external power source, such as the SONY MVC-FD200 AC adapter or USB charging cable.
- If the camera powers on while plugged into a power source, this indicates a problem with the battery or the internal power circuit
If the camera works while plugged in but not on battery power, consider replacing the battery, as it might be unable to hold a charge. If the problem continues even with a new battery, it could be an issue with the internal power circuit, which may need professional servicing.
If none of the previous solutions work, there could be an issue with the camera’s internal power circuits or motherboard. This can happen due to internal damage from impacts, moisture exposure, or manufacturing defects.
- Unfortunately, diagnosing and repairing internal circuit issues requires technical expertise. A faulty power circuit may prevent the camera from turning on despite having a fully charged battery.
In this case, the best course of action is to contact SONY customer support or visit an authorized repair center. Technicians will be able to run diagnostic tests to identify the exact cause and repair the internal circuits if necessary. If the camera is under warranty, this may be covered by SONY’s repair services.
