Shop the Holiday Gift Guide
Keys Not Responding
Madison A and 1 contributor
Last updated on Causes
- A simple problem might be the build-up of debris underneath the keys. Over the years, with low maintenance, debris can build up underneath the keys on your keyboard and cause them to get stuck. There are two ways to fix this problem.
- By going to a local Walmart or Best Buy, you can find compressed air cans commonly used to blow out debris. Do this by tilting the keyboard and pointing the can nozzle between keys until fully cleared.
- Remove keys individually, clean out the main board from any debris with a lightly damped paper towel or compressed air can, and then clean each key before putting them back in place.
- The best way to avoid this is to reduce eating around your device and maintain a more frequent cleaning schedule for the keyboard.
- Similar to debris build-up, sticky keys are normally caused by liquids building up in between keys due to spills. This causes them to either stick to the board and not be able to pop back up after being pressed or keep them from being pressed down altogether.
- Remove keys individually. Clean each key and the keyboard with a disinfecting wipe. Let everything dry completely before putting it back together.
- Avoid this by reducing the amount of liquids near or around the keyboard so there is less spillage.
- A more common issue than not when keys are not responding is a connection issue with the device the keyboard is connected to.
- Make sure all cords are connected/plugged in completely to the device that the keyboard is connected to. Simply remove the cord from plug in then reconnect, fully pushing the cord into the port.
Related Problems
Logitech G213 Prodigy
3 problems · View all
Describe your problem in your own words
View statistics:
Past 24 Hours:7
Past 7 Days:38
Past 30 Days:207
All Time:3,186
