Causes
The device should come paired to the USB adapter from the package. However, if the microphone is not working properly, repairing the device may fix the issue.
- Make sure the headset is powered off. Plug the USB adapter into your Xbox.
- Use a small pin to press the small button located in a small hole on one side of the USB adapter. After 3 seconds, it should begin to blink.
- Press and hold the headset power button for 10 seconds to enter pairing mode. The headset LEDs should begin to blink.
- After the USB adapter and headset LEDs stay a solid light, they are now paired.
It is possible the microphone is not inserted properly. Inspect the detachable microphone that is packaged with your HyperX CloudX Flight.
- Ensure that the 3.5 mm jack connector is clean and intact.
- Ensure that the 3.5 mm jack port on the device is free of debris and in good condition.
- Insert the microphone back into the port until the microphone is seated firmly within the device’s port.
Haven't found the solution to your problem?Browse our forum
