Smart Soldering Iron Tip Is Disconnected
Sandra Hiller
Last updated on
The iron is showing an error which indicates that the tip is disconnected.
Causes
Solution:
Make sure the tip is fully inserted so the barrel of the tip is slightly below the surface of the Smart Soldering Iron that surrounds the tip insertion point.
Solution:
Remove the tip and examine the connection for debris or damage.
Clean the tip contacts with a contact cleaner.
3
Solution:
Disassemble the Smart Soldering Iron and examine the internal socket for damage or debris.
  • Make sure the socket has not come loose from the mainboard.
  • You can insert a soldering tip into the socket, and then with gentle pressure check to see if the socket is loose.
  • Use contact cleaner to clean the socket contacts.
4
Solution:
If you have another tip, try it in the iron to see if the error goes away. If it does, then the tip causing the error is defective and needs replacement. Contact Support for help with replacement if the tip is still fairly new.
Contact support if you have tried these fixes for further guidance and help.
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
43
All Time:
168
