Causes
If the controller is relaying that it is partially charged, a controller reset is necessary. To reset the controller:
- Turn on the controller
- Turn the controller around
- Press the C1, C2, and Shutter buttons at the same time.
Once done in succession, you will hear a small beep noise. At this indication, turn the controller off. Wait a moment and then press the power button. All battery indicator lights should turn on.
The controller battery will need to be unplugged. Wait a moment after unplugging the battery, then plug it back in. Turn the controller on and if it indicates that it is not fully charged, then replace the battery.
- 15 - 30 minutesEasy
This controller runs on a 6000mAh/44.40Wh battery pack, which you can buy here. Follow the battery replacement guide to properly switch out the battery.
Describe your problem in your own words
