Causes
The Anker Soundcore Life Q20 headphones may need to be reset if they are not charging correctly.
- Delete the pairing history from your Bluetooth device.
- On the headphones, press and hold the volume up button and power button simultaneously for 5 seconds.
- The LED indicator should flash red three times.
If encountering problems with holding power or charging, the battery may be faulty. Follow the step-by-step directions in Anker Soundcore Life Q20 Battery Replacement to replace the battery.
- 15 - 20 minutesModerate
The charging cord and block for the headphones may be faulty or broken.
- Leave the headphones plugged in for 24 hours to see if they charge.
- Test the charger with another device to ensure that the charger is working properly.
- If you find that the cable or block of the charger are not working, try another charger. Soundcore recommends that you use a 5V charger.
You're seeing solutions for Anker Soundcore Life Q20+. Select your model to find parts for your device.
Describe your problem in your own words
View statistics:
Past 24 Hours:1
Past 7 Days:16
Past 30 Days:125
All Time:1,369
