Polyimide Tape
Polyimide Tape
.5" is the most common size of Polyimide tape found in Apple products. Same as part# 922-1731
$9.99
$9.99
We'll send a message when the product is back in stock.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Product Details
Features
Features
Polyimide tape is utilized in electronic components for space exploration as well as Apple products. It is a low-outgassing material with high temperature resistance, excellent thermal conductivity, and low radiation interference. Indispensable as masking in wave soldering and powder coating, Polyimide's properties make it ideal for electric insulation in X-Ray devices and radioactive environments too. Polymide is the perfect super tape for any space age atomic sci-fi mad scientist application. Note: Does not block X-Ray vision or Kryptonite rays, red or green.*
Our Polyimide tape is a perfect match for the .5" width tape most often used by Apple. You may only need a few inches, but this 108 foot roll is priced cheap enough to share with your friends or keep it as a lifetime supply!
*We recommend thorough testing by individual super heroes.
This tape is compatible with the properties of and can be used in place of 3M Kapton® polymide tape part# KPT-1/2.
Repair Stories
User avatar
marwan's Story Photo #594776
My Problem
A few days ago the screen would not come on from over night computer sleep. I did the usual thing starting with repairing permissions (knowing that it most likely not related to this issue), zapping the PRAM, unplugging the power cord/removing the battery holding the power button on for a good 15 s . . .
User avatar
My Problem
Replacing the Battery
My Fix
Smooth until putting the white double sided tape on the new battery. I pulled the blue backing, but the I wanted to check something and put the blue backing back over the tape. When I went to remove the blue backing it was stuck on...I guess one side is not the same as the other . . .
User avatar
My Problem
Sreen broken
My Fix
Good. Don't know yet. I don't have service so, I think i might have done something wrong.
My Advice
User avatar
My Problem
Smashed screen.
My Fix
It was easy with the right tools.
My Advice
I use muffin pans to organize screws and small parts.
User avatar
My Problem
The Battery was showing signs of dying. Only stayed charged for an hour or two
My Fix
With the iSclack it went really well. Super easy to get into. And not much needed to come apart. But the battery took the longest to get it unglues from the back of the device. Like 10 mins kinda unglued.
My Advice
Try and warm up th . . .
User avatar
My Problem
My iPhone 4s was still a trusty companion but was starting to run out of gas early in the day. I was spending more money and more time on extra external battery packs to make it through the day and increasing amounts of time on the logistics of tracking what was charged and herding all the various c . . .
User avatar
My Problem
Hard Drive was too full to Update or Even Backup ... 250Gb
My Fix
Bought a 500GB drive and rolled up my sleeves .. .. OOPs the guide called for lots of hardware I didn't have. The Driver kit was bought to replace the internal battery on my stepson's powerbook, but i was glad I had it when I got to the itt . . .
User avatar
My Problem
My MacBook keyboard after seven years, lots of typing and one errant berries smoothie later, was missing a few keys and had totally lost the use of its delete key. But the final straw was an e key that had decided to either not work or depress itself continuously mid-typing likeeeeeeeeeeeeeeeeeeeeee . . .
Show more
