MacBook Unibody (A1342 Late 2009-Mid 2010) Replacement Battery
  • MacBook Unibody (A1342 Late 2009-Mid 2010) Replacement Battery / New / Fix Kit
  • MacBook Unibody (A1342 Late 2009-Mid 2010) Replacement Battery / New / Part Only
  • 360°
360
$84.99
$84.99
We'll send a message when the product is back in stock.
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Product Details
Description
Description
This Replacement Battery compatible with MacBook Unibody (Model No. A1342 Late 2009/Mid 2010) is what you need to bring your laptop back back to life. Our aftermarket replacement batteries lead the industry in quality and reliability—each is tested and guaranteed to have a capacity greater than 5510 mAh—so you know you're getting the best money can buy.
Kit Contents
Kit Contents
Note
Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.
Warning
Lithium-ion batteries pose a fire hazard if they swell due to age or defect. Learn more about safe handling and proper disposal of all batteries.
Compatibility
Repair Stories
User avatar
nickmalmquist's Story Photo #1376790
My Problem
Battery life was less and less, and OSX said to replace soon. I also wanted to replace my original hard drive with an SSD.
My Fix
The two replacements were almost seamless. The first minor problem was that I did not get the tri-lobe screwdriver to remove the battery screws. I managed to get the job done wit . . .
User avatar
mmarkovich's Story Photo #504303
My Problem
Battery was out completely, swapped it out with a new iFixit battery.
My Fix
Once swapped the computer did not turn on. After a day of stress, found that the problem was the small connector left of where the battery plugs in. It had come loose slightly. With tape, nudged it back in to position. This is the . . .
User avatar
My Problem
Dead battery
My Fix
Went fine, was easy to replace...
My Advice
if it needs replaced, don't hesitate, replace it
User avatar
My Problem
My wife's Macbook battery expanded, blowing out the trackpad and stretching the back cover. I guess it's $129 from apple to replace the battery, but we don't live near an apple store. I ordered the battery from IFIXIT and it was about $106 with tax. I searched other batteries on Amazon and other sto . . .
User avatar
My Problem
After upgrade to OS El Capitain, my macbook was too slow. On the same time, the battery was down for an intensive use during 6 years.
My Fix
Perfect!!! The battery was fitted and recognized by system and my macbook accept 8 gb of ram. The HD was ok and i used a software called "trim enabler" to activate T . . .
User avatar
My Problem
Dead battery on late 2009 Macbook (A1342).
My Fix
Replacement. Slightly more difficult than changing the batteries in your TV remote. Follow the instructions. They are very simple and to the point.
My Advice
Use the right tools for the job! Buy the tool kit as it has everything you will need.
Plus, once untethere . . .
User avatar
My Problem
My partners late 2009 Macbook started to fall apart all at once. The rubberised bottom peeled off, the batter stopped holding a charge and the fan failed.
I replaced the laptop with a new macbook and kept the old one until it failed completely which was the day after it was replaced.
A year later . . .
User avatar
My Problem
Battery went bad
My Fix
ordered the correct part and was fixed in a minute
My Advice
nope
User avatar
My Problem
battery was dead and magsafe board failed
My Fix
everything was great, i had 1 screw stripped from a previous repair but it wasn't too much of an issue and i broke 1 speaker connector , but that speaker was already blown and will be replaced once i can afford it.
My Advice
be very gentle with the speaker connectors, t . . .
User avatar
My Problem
After 5 years, the battery simply couldn't keep working anymore. So it was time to replace it.
My Fix
It was an easy and clear unmounting, replacement and mounting. The battery is real easy to replace, just follow the steps carefully on the tutorial.
My Advice
Careful on your tools! The tri-wing battery screw is reall . . .
Show more
