MacBook Pro 13" Unibody (Mid 2009 - Mid 2012) Trackpad
  • MacBook Pro 13" Unibody (Mid 2009 - Mid 2012) Trackpad / No Screws / New
  • 360°
360
Includes the 4 mounting screws and the set screw.
$89.99
$89.99
We'll send a message when the product is back in stock.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Product Details
Description
Description
Trackpad problems getting you down?
Wrangle your unruly cursor with a well behaved trackpad! No more more random mouse jumping, missed clicks, or erratic tracking - regain control of your computer and point and click that cursor to wherever your heart desires.
Feel confident in your purchase - all of our Used Trackpads are cosmetically inspected and functionally tested in house and come with a lifetime warranty. Help extend the life of your computer with a used trackpad and feel good knowing that you're part of a sustainable economy and have kept a functional part out of the landfill.
Find the screws and other mounting hardware for sale separately here.
Compatibility
Repair Stories
User avatar
Jonathan Fedor's Story Photo #1329984
My Problem
The trackpad on my wife's Macbook Pro went south. There were a couple instances of a small amount of water getting down below the surface of the computer and the last time caused the trackpad to bite the dust.
My Fix
The repair was successful! I was really excited to order my first part from iFixit. The par . . .
User avatar
My Problem
non-working trackpad
My Fix
Fine, except for the keeping track of the oh-so-small screws
My Advice
Use a magnetic screwdriver to handle the small screws
User avatar
My Problem
Cursor non responsive. USB mouse functional, suspected trackpad failure.
My Fix
Uneventful. I've done literally hundreds of trackpad replacements.
My Advice
Use edge of post it notes wedged in between where the trackpad seats and the top case to create an equal distance all around the edge of the trackpad. Remove post . . .
User avatar
My Problem
Track pad no longer worked
My Fix
Followed the instructions to the T. The repair went easy as pie.
My Advice
Be very careful with the trackpad screws. They are very small and easily stripped. Consider buying the screws. If I did this repair again I would buy the screws.
User avatar
My Problem
The trackpad was worn out where it was not very responsive to clicking it. I tightened and loosened the click adjustment screw but the trackpad was frustratingly not sensitive enough where it took repetitive clicks
My Fix
The repair was a piece of cake! The guide gave me the confidence that I could do it.
My Advice
I . . .
User avatar
My Problem
The tracking pad was sensing false movements.
My Fix
The repair went fine. The black screws that came with it, however, did not fit. Fortunately, I had the original screws and used them.
My Advice
The black screws that came with the tracking pad did not fit. Fortunately, I had the original screws and used them.
User avatar
My Problem
The trackpad had sporadically lost functionality, first not clicking audibly, then not responding to a two finger swipe, etc. It suddenly stopped responding altogether. I took it apart to clean it, and noticed a plastic cap that was floating around the area instead of stuck decently to the end of . . .
User avatar
My Problem
The trackpad was damaged by a dying battery which expanded and pushed up against the trackpad.
My Fix
The replacement went well, although the guide was for a 2011 macBook, so slightly different
My Advice
The trackpad for the 2010 MacBook uses a little yoke to hold the trackpad in place. This doesn't show up in the gui . . .
User avatar
My Problem
My trackpad was not ok,because the arrow jumped all over the screen
My Fix
Very quick shipping and ,the replacement went very smooth,used 5 minutes and everything is working as normal
My Advice
User avatar
My Problem
The trackpad on my Macbook Pro started seriously wigging out about six months ago. I ruled out software issues and, wary of the Mac store, decided to just get a good 'ol fashioned USB mouse after disabling the trackpad entirely. Needless to say, things got weird with the cord. Some weeks later, I op . . .
Show more
