MacBook Pro 13" Unibody (Early 2011-Mid 2012) Upper Case
  • MacBook Pro 13" Unibody (Early 2011-Mid 2012) Upper Case
  • MacBook Pro 13" Unibody (Early 2011-Mid 2012) Upper Case / A-Stock / No Keyboard
This used part is in excellent condition.
$132.99
$132.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
Replace a broken or damaged upper case, including the backlit keyboard, for your Early 2011-Mid 2012 MacBook Pro 13" Unibody laptop computer with this part.
Note
Looking for the trackpad: MacBook Pro 13" Unibody (Mid 2009 through Mid 2012) Trackpad
Disclaimer
All options offered do not contain the backlit keyboard, so be sure to select the appropriate option you need!
Install Video
Repair Stories
richardaskew's Story Photo #292342
My Problem
Over a month ago my son spilled a full pint of milk into his laptop. After 9 months of hectoring him to treat his new macbook pro with care he paid the ultimate price, it was completely dead. The chickens (or cows) had come home to roost. I took it to the expert repairers who delivered the final blo . . .
My Problem
I was replacing the heat sink material, when in disassembling the computer the plastic connector to the keyboard on the logic board broke. So I had to replace the logic board. Then it turned out I also damaged the keyboard ribbon cable when trying to jam it into the broken zif connector - who design . . .
My Problem
I'd inherited a 2012 MBP that had pancake batter drip into the keyboard, rendering half the keys inoperable. Wanted to fix it to send to high school with my daughter - runs MacOS High Sierra, and the battery is still decent.
My Fix
It took a while, and there were support structures that I needed to transfer . . .
My Problem
Keyboard not working
My Fix
After replacing upper case., keyboard now functional.
My Advice
Screws are very tiny. Get yourself a magnetic tip screw driver kit.
My Problem
My keyboard had water damage and didnt work
My Fix
Amazing, super easy instructions
My Advice
Get the i fix it tray to track your 50 odd screws, i think this made reassembly easier.
My Problem
So, I had a friend over, and we were doing some drinking, and I had my Macbook (Mid 2012 Unibody) plugged up to the tv. Apparently after I went to sleep my friend started feeling sick. He ended up vomiting and I suppose he couldn't make it to the bathroom, because he ended up throwing up in the empt . . .
My Problem
I put the laptop in a bag that had some sand vestiges on it (without realizing), some of it got on the keyboard. At first I tried to clean it, but it didn't go so well - had to end up changing the keyboard.
My Fix
Went well, took a little longer than other reports I saw. Maybe 5h total.
My Advice
When putting the spea . . .
My Problem
A bottle of sprite was foolishly left with the cap unfastened and was knocked over. It was picked up in less than a second but the massive splash of soda landed on my macbook pro keyboard. I was able to quickly dab up the spillage before any damage to major internal components occurred but the key . . .
My Problem
spilled lemonade on keyboard
My Fix
using the guide the repair went smoothly, no issues
My Advice
the tool kit is awesome and necessary
My Problem
Typical case of water spill on the keyboard. Did everything right to cut power, allow to dry, but some weeks later my keyboard starting acting possessed. The 7 key would not work, but the computer knew how to type it, intermittently, ad-nausea. A few weeks later and the upper right keys on the ke . . .
Show more
