MacBook Pro 13" Retina (Early 2015) Battery
  • MacBook Pro 13" Retina (Early 2015) Battery / New / Fix Kit
  • MacBook Pro 13" Retina (Early 2015) Battery / New / Part Only
  • 360°
360
New battery guaranteed at capacity greater than 6230 mAh.
$109.99
$109.99
We'll send a message when the product is back in stock.
Product Details
Description
Description
This replacement battery is what you need to get your MacBook Pro 13" Retina (Early 2015) back in action! These batteries are adhered to the upper case of the computer so removing them isn't as straightforward as we'd like it to be. Be sure you have all the right tools—and follow our repair guide when making the repair.
Part Assembly Includes
  • Installation adhesive
Kit Contents
Kit Contents
Note
Lithium ion battery shipping regulations limit the shipping methods for orders containing batteries. Domestic orders may only be shipped via Standard shipping. iFixit is not able to ship batteries internationally or outside the contiguous US at this time. iFixit Customer Support will contact you if your order needs to be modified after it is placed.
Disclaimer
MacBook Pro Retina batteries are originally adhered to the upper case assembly as a single part from Apple. The parts we sell may have been separated from this assembly. Consequently, the battery adhesive may have some cosmetic flaws.
Warning
Lithium-ion batteries pose a fire hazard if they begin to swell due to age or defect. Learn more about how to safely handle a battery that may be swollen.
Compatibility
Repair Stories
Leo de la Cruz's Story Photo #1273682
My Problem
After only 210 charging cycles, my battery went completely dead.
My Fix
I used the MacBook Pro 13" Retina (Early 2015) Battery fix kit, which had everything I needed to complete the install (tools, gloves, safety glasses, etc.). I just finished my install about 20 minutes ago, and so far, so good. Battery i . . .
My Problem
Dead battery - would only work on AC power
My Fix
Pretty much easy-peasy; went off without a hitch. It took a bit over an hour. The step by step instructions were very clear.
My Advice
The only semi-issue I had was step 19: flipping up the retaining tab to get the trackpad cable out of the ZIF connector. It's a very . . .
My Problem
We have two MacBook Pros both with failed or failing batteries. The estimate for professional repair was 3 times the cost of iFixit's kit, including the additional tool kit with the heating pad.
My Fix
The plan was to replace the battery in the MacBook Pro (13-inch, Early 2011) first to build my confidence . . .
My Problem
I spilled a small amount of water (probably less than 1 tsp) on the MacBook. From that moment on, it only worked when plugged in and the diagnostics told me I needed a new battery. I have complete Apple Care coverage but not the new Apple Care Plus (which would cover the spill) and it was no help . . .
My Problem
My wife accidently spilled water onto keyboard, Result - Laptop became Desktop. The laptop always required to be hooked up to charger to turn it on. Took it to apple store they said its water damage and have to replace more than battery and will cost me $800 +, Used it for a year like that before gi . . .
My Problem
My housemate spilled a full glass of milk on the keyboard and it killed the battery.The laptop only worked while plugged in and that was such a hassle during school because I would have to sit next to a power outlet, if not then I wouldn't be able to work on anything.
My Fix
The repair was such a breeze. Th . . .
My Problem
Customer spilled mike over the keyboard and after he dried out (as per Apple instructions) it showed a: need to replace battery error.
My Fix
It went great!
My Advice
Only thing I can say is, I'll be repairing Apple's now. IFIXIT made it so easy for me. The online Repair Guide was great and walked me right through th . . .
My Problem
After replacing my Keyboard (Just the keyboard, I did not buy a whole new uppercase assembly, but at one point I wish I had...), I had somehow damaged my battery. The entire point of fixing my keyboard was to make my laptop more portable again (I was sick of always having to pack my wired usb keyboa . . .
My Problem
Apparently "the teenager" who got a new MacBook pro for graduation spilled some water (maybe beer) on the keyboard. Knowing said teenager is susceptible to accidents (countless broken iPhone screens) we had purchased AppleCare. One thing AppleCare doesn't cover is Water damage :( They wanted $855 . . .
My Problem
The battery monitor was saying replace now.
My Fix
It was great, a very accurate guide.
My Advice
Follow the instructions carefully and heed all warnings.
Show more
