15% Off Selected iFixit Tools — Limited Time
MacBook Air Parts
Replacement parts for DIY MacBook Air repair
Fix what's broken. Upgrade what's not. iFixit makes MacBook Air repair easy: strictly tested, quality-ensured replacement parts, unmatched DIY fix kits, and free in-depth, accurate repair manuals.
Products
279 results
iFixit Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating.
Number of reviews:70
$24.95
Apple MagSafe 2 AC Adapter
Replace a broken or damaged Apple MagSafe 2 AC adapter with this part.
Number of reviews:39
Lifetime Guarantee
$39.99
MacBook Air 13" (Late 2018-Late 2020) USB-C Board
Replace a dirty, corroded, or damaged USB-C connector board from the left side of your laptop. This part is compatible with a Late 2018 to Late 2020 13" MacBook Air. Part #820-01161, 821-01658.
Number of reviews:111
Lifetime Guarantee
$19.99
MacBook Air 11" (Mid 2011-Early 2015) Battery
Replace a 5100 mAh battery compatible with the MacBook Air 11" Mid 2011 to Early 2015 A1370 and A1465 model laptop. 38.75 Watt Hours (Wh). 7.6 Volts (V). Battery model A1495.
Number of reviews:362
$59.99
Apple MagSafe 1 AC Adapter
Replace a broken or damaged Apple MagSafe 1 AC 45W adapter with this part.
Number of reviews:40
Lifetime Guarantee
$39.99
MacBook Air 13" (A2681, 2022) Battery
Replace a 4561 mAh battery compatible with a MacBook Air 13" M2 2022 A2681 model laptop. 52.6 Watt Hours (Wh). 11.54 Volts (V). Battery model A2669.
Number of reviews:2
$99.99
Only 1 left in stock
MacBook Air 13" (A2337, Late 2020) Display Assembly
Replace a display compatible with the model A2337 late 2020 13" Retina MacBook Air 13" laptop. Includes the 2560 x 1600 pixel LCD 13.3" screen, aluminum case, camera.
Number of reviews:33
Lifetime Guarantee
$399.99
MacBook Air 13" (Mid 2013-2017) I/O Board
Replace a used I/O board compatible with the Mid 2013 to 2017 MacBook Air 13" laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe 2 power, USB, and audio ports.
Number of reviews:24
Lifetime Guarantee
$34.99
Only 8 left in stock
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
Number of reviews:125
$11.99
MacBook Air 13" (A2179, A2337 2020) Trackpad Cable
Replace a torn or damaged cable that connects the trackpad and keyboard to the logic board compatible with the model A2179 or A2337 2020 13 inch MacBook Air laptop. Part #821-02663.
Number of reviews:3
Lifetime Guarantee
$14.99
MacBook Air 15" (2023) Battery
Replace a 5762 mAh battery compatible with a MacBook Air 15" 2023 A2941 model laptop. 66.5 Watt Hours (Wh). 11.54 Volts (V). Battery model A2797.
Number of reviews:1
$99.99
MacBook Air 13" Retina (A2337) Key Caps
A complete set of key caps for your MacBook Air 13" Retina (A2337) keyboard. Replace worn key caps of your laptop.
Number of reviews:10
Lifetime Guarantee
$17.99
MacBook Air 13" (A2681, 2022) Trackpad Cable
Replace the cable that connects the trackpad to the logic board. Compatible with a model A2681 MacBook Air M2 2022 laptop.
Number of reviews:3
Lifetime Guarantee
$19.99
Only 9 left in stock
MacBook Air 13" (Late 2018-Early 2020) Fan
Replace a fan compatible with Late 2018 to Early 2020 MacBook Air 13" A1932 or A2179 model laptops. Part #923-0442, 923-00507.
Number of reviews:3
Lifetime Guarantee
$19.99
MacBook Air 13" (Late 2018-Early 2020) Display Assembly
Replace a display compatible with the model A1932 Late 2018 to 2019 and A2179 Early 2020 13" Retina MacBook Air 13" laptop. Includes the 2560 x 1600 pixel LCD 13.3" screen, aluminum case, camera. Part #661-09735, 661-12588.
Lifetime Guarantee
$464.99
