Fix Your Stuff
Right to Repair
Parts & Tools
MacBook Air (Original-Mid 2009) Replacement Battery
  • MacBook Air (Original-Mid 2009) Replacement Battery / Fix Kit
  • MacBook Air (Original-Mid 2009) Replacement Battery / Part Only
$69.99
$69.99
We'll send a message when the product is back in stock.
LCD iPhone Screen Fix Kits
The budget option, covered by our Lifetime Warranty.
Shop Kits
Cut repair costs, not quality.
Shop Kits
Product Details
Description
Description
This MacBook Air (Original-Mid 2009) replacement battery is what you need to bring your dead laptop back to life!
  • 100% factory tested.
  • Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 5280 mAh.
  • Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
  • Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your MacBook Air's lifespan, extend it with this new replacement battery compatible with MacBook Air (Original-Mid 2009). Factory-installed MacBook Air (Original-Mid 2009) batteries are rated to last 300 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Kit Contents
Kit Contents
Compatibility
Compatibility
  • MacBook Air 13" A1237 Original
  • MacBook Air 13" A1304 Late 2008 to Mid 2009
Specifications
Specifications
Part #:
661-4587, 661-4915
Model #:
A1245
Watt Hours:
40 Wh
Voltage:
7.2 V
Milliamp Hours:
5560 mAh
Manufacturer:
Aftermarket
Compatibility
MacBook Air Models A1237 and A1304
EMC 2142 1.6 GHz (Original)
EMC 2142 1.8 GHz (Original)
EMC 2253 1.6 GHz (Late 2008)
EMC 2253 1.86 GHz (Late 2008)
EMC 2334 1.86 GHz (Mid 2009)
EMC 2334 2.13 GHz (Mid 2009)
Customer Reviews
