iPhone 7 Plus Taptic Engine Replacement
  1. iPhone 7 Plus Taptic Engine Replacement, Pentalobe Screws: step 1, image 1 of 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Plus Taptic Engine Replacement, Opening Procedure: step 2, image 1 of 1
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. iPhone 7 Plus Taptic Engine Replacement: step 3, image 1 of 2 iPhone 7 Plus Taptic Engine Replacement: step 3, image 2 of 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 7 Plus Taptic Engine Replacement: step 4, image 1 of 3 iPhone 7 Plus Taptic Engine Replacement: step 4, image 2 of 3 iPhone 7 Plus Taptic Engine Replacement: step 4, image 3 of 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
    • While pulling up on the suction cup, twist the spudger to widen the opening between the screen and rear case.
  5. iPhone 7 Plus Taptic Engine Replacement: step 5, image 1 of 3 iPhone 7 Plus Taptic Engine Replacement: step 5, image 2 of 3 iPhone 7 Plus Taptic Engine Replacement: step 5, image 3 of 3
    • Insert the flat end of the spudger between the front panel and the rear case at the lower left edge of the iPhone.
    • Slide the spudger up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
  6. iPhone 7 Plus Taptic Engine Replacement: step 6, image 1 of 2 iPhone 7 Plus Taptic Engine Replacement: step 6, image 2 of 2
    • Remove the spudger from the left side of the phone and insert the flat end into the bottom right corner.
    • Slide the spudger up the right edge of the phone to the top corner, breaking up the adhesive holding the display in place.
  7. iPhone 7 Plus Taptic Engine Replacement: step 7, image 1 of 2 iPhone 7 Plus Taptic Engine Replacement: step 7, image 2 of 2
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10º as there are delicate ribbon cables along the right edge of the device connecting the display to the logic board.
  8. iPhone 7 Plus Taptic Engine Replacement: step 8, image 1 of 2 iPhone 7 Plus Taptic Engine Replacement: step 8, image 2 of 2
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  9. iPhone 7 Plus Taptic Engine Replacement: step 9, image 1 of 2 iPhone 7 Plus Taptic Engine Replacement: step 9, image 2 of 2
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
  10. iPhone 7 Plus Taptic Engine Replacement: step 10, image 1 of 3 iPhone 7 Plus Taptic Engine Replacement: step 10, image 2 of 3 iPhone 7 Plus Taptic Engine Replacement: step 10, image 3 of 3
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  11. iPhone 7 Plus Taptic Engine Replacement, Battery Disconnection: step 11, image 1 of 1
    • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
    • Three 1.2 mm screws
    • One 2.6 mm screw
  12. iPhone 7 Plus Taptic Engine Replacement: step 12, image 1 of 2 iPhone 7 Plus Taptic Engine Replacement: step 12, image 2 of 2
    • Remove the lower display cable bracket.
  13. iPhone 7 Plus Taptic Engine Replacement: step 13, image 1 of 3 iPhone 7 Plus Taptic Engine Replacement: step 13, image 2 of 3 iPhone 7 Plus Taptic Engine Replacement: step 13, image 3 of 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  14. iPhone 7 Plus Taptic Engine Replacement, Display Assembly: step 14, image 1 of 3 iPhone 7 Plus Taptic Engine Replacement, Display Assembly: step 14, image 2 of 3 iPhone 7 Plus Taptic Engine Replacement, Display Assembly: step 14, image 3 of 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  15. iPhone 7 Plus Taptic Engine Replacement: step 15, image 1 of 3 iPhone 7 Plus Taptic Engine Replacement: step 15, image 2 of 3 iPhone 7 Plus Taptic Engine Replacement: step 15, image 3 of 3
    • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.3 mm screw
    • Two 1.0 mm screws
    • Remove the bracket.
  16. iPhone 7 Plus Taptic Engine Replacement: step 16, image 1 of 2 iPhone 7 Plus Taptic Engine Replacement: step 16, image 2 of 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  17. iPhone 7 Plus Taptic Engine Replacement: step 17, image 1 of 1
  18. iPhone 7 Plus Taptic Engine Replacement, Barometric Vent: step 18, image 1 of 1
    • Remove the following two Phillips screws securing the barometric vent to the rear case:
    • One 2.9 mm screw
    • One 2.1 mm screw
  19. iPhone 7 Plus Taptic Engine Replacement: step 19, image 1 of 2 iPhone 7 Plus Taptic Engine Replacement: step 19, image 2 of 2
    • Gently push the barometric vent in the direction of the Taptic Engine to separate the adhesive securing it to the bottom edge of the iPhone.
  20. iPhone 7 Plus Taptic Engine Replacement: step 20, image 1 of 1
    • Remove the vent.
  21. iPhone 7 Plus Taptic Engine Replacement, Taptic Engine: step 21, image 1 of 2 iPhone 7 Plus Taptic Engine Replacement, Taptic Engine: step 21, image 2 of 2
    • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
  22. iPhone 7 Plus Taptic Engine Replacement: step 22, image 1 of 1
    • Remove the three 1.5 mm Phillips screws securing the Taptic Engine to the rear case.
  23. iPhone 7 Plus Taptic Engine Replacement: step 23, image 1 of 2 iPhone 7 Plus Taptic Engine Replacement: step 23, image 2 of 2
    • Remove the Taptic Engine.
Scott Havard
49,663 Reputation
31 Guides authored
Past 24 Hours: 12
Past 7 Days: 50
Past 30 Days: 294
All Time: 42,216
