iPhone 7 Lightning Connector Assembly Replacement
  1. iPhone 7 Lightning Connector Assembly Replacement, Pentalobe Screws: step 1, image 1 of 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Lightning Connector Assembly Replacement, iPhone 7 Opening Procedure: step 2, image 1 of 1
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. iPhone 7 Lightning Connector Assembly Replacement: step 3, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 3, image 2 of 2
    • Attach a suction cup to the lower half of the display assembly, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 7 Lightning Connector Assembly Replacement: step 4, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 4, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 4, image 3 of 3
    • Pull up on the suction cup to create a small gap between the display assembly and the rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong, and creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
  5. iPhone 7 Lightning Connector Assembly Replacement: step 5, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 5, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 5, image 3 of 3
    • Slide the spudger to the left along the lower edge of the iPhone.
    • Twist the spudger to widen the gap between the display and rear case.
  6. iPhone 7 Lightning Connector Assembly Replacement: step 6, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 6, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 6, image 3 of 3
    • Slide the spudger up the left side of the iPhone, starting at the lower edge and moving towards the volume control buttons and silent switch.
    • Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display.
  7. iPhone 7 Lightning Connector Assembly Replacement: step 7, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 7, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 7, image 3 of 3
    • Insert the flat edge of a spudger into the bottom right corner of the device.
    • Twist the spudger to widen the gap between the display assembly and the rear case.
    • Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
    • Do not insert the spudger further than the adhesive to avoid damaging delicate ribbon cables along the right edge.
  8. iPhone 7 Lightning Connector Assembly Replacement: step 8, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 8, image 2 of 2
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10º as there are ribbon cables along the right edge of the device connecting the display to the logic board.
  9. iPhone 7 Lightning Connector Assembly Replacement: step 9, image 1 of 1
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  10. iPhone 7 Lightning Connector Assembly Replacement: step 10, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 10, image 2 of 2
    • Slide an opening pick along the top edge of the iPhone, between the rear case and front panel, to break up the remaining adhesive holding the screen in place.
    • Be careful not to damage the plastic clips on the top edge of the phone.
  11. iPhone 7 Lightning Connector Assembly Replacement: step 11, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 11, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 11, image 3 of 3
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  12. iPhone 7 Lightning Connector Assembly Replacement, Battery Disconnection: step 12, image 1 of 1
    Tool used on this step:
    Tri-point Y000 Screwdriver
    $5.99
    Buy
  13. iPhone 7 Lightning Connector Assembly Replacement: step 13, image 1 of 1
    • Remove the lower connector bracket.
  14. iPhone 7 Lightning Connector Assembly Replacement: step 14, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 14, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 14, image 3 of 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  15. iPhone 7 Lightning Connector Assembly Replacement, Display Assembly: step 15, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement, Display Assembly: step 15, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement, Display Assembly: step 15, image 3 of 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  16. iPhone 7 Lightning Connector Assembly Replacement: step 16, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 16, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 16, image 3 of 3
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
  17. iPhone 7 Lightning Connector Assembly Replacement: step 17, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 17, image 2 of 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  18. iPhone 7 Lightning Connector Assembly Replacement: step 18, image 1 of 1
  19. iPhone 7 Lightning Connector Assembly Replacement, Barometric Vent: step 19, image 1 of 1
    • Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
  20. iPhone 7 Lightning Connector Assembly Replacement: step 20, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 20, image 2 of 2
    • Remove the vent.
  21. iPhone 7 Lightning Connector Assembly Replacement, Taptic Engine: step 21, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement, Taptic Engine: step 21, image 2 of 2
    • Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
  22. iPhone 7 Lightning Connector Assembly Replacement: step 22, image 1 of 1
    • Remove the three 1.6 mm Phillips screws securing the Taptic Engine to the rear case.
  23. iPhone 7 Lightning Connector Assembly Replacement: step 23, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 23, image 2 of 2
    • Remove the Taptic Engine.
  24. iPhone 7 Lightning Connector Assembly Replacement, Speaker Assembly: step 24, image 1 of 1
    • Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
    • One 3.2 mm screw
  25. iPhone 7 Lightning Connector Assembly Replacement: step 25, image 1 of 1
    • Remove the following three Phillips screws securing the speaker to the rear case:
    • Two 1.3 mm screws
    • One 2.0 mm screw
  26. iPhone 7 Lightning Connector Assembly Replacement: step 26, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 26, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 26, image 3 of 3
    • Use the point of a spudger to lift the two antenna cable connectors up off of the sockets on the logic board.
  27. iPhone 7 Lightning Connector Assembly Replacement: step 27, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 27, image 2 of 2
    Buy
    • Use tweezers to derout the antenna cables from their bracket on the logic board.
  28. iPhone 7 Lightning Connector Assembly Replacement: step 28, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 28, image 2 of 2
    • Use tweezers to remove the antenna cables from the clip on the speaker.
    • Make sure to grasp the cable near the clip in order to avoid damaging the cable.
  29. iPhone 7 Lightning Connector Assembly Replacement: step 29, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 29, image 2 of 2
    • Use the tip of a spudger to slide the speaker assembly towards the logic board and off of the rear case.
  30. iPhone 7 Lightning Connector Assembly Replacement: step 30, image 1 of 1
    • Remove the speaker.
  31. iPhone 7 Lightning Connector Assembly Replacement, SIM Card: step 31, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement, SIM Card: step 31, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement, SIM Card: step 31, image 3 of 3
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force. However, ensure the eject tool is properly aligned beforehand as to not damage the eject mechanism inside the phone.
    • Remove the SIM card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  32. iPhone 7 Lightning Connector Assembly Replacement, Logic Board Connectors: step 32, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement, Logic Board Connectors: step 32, image 2 of 2
    • Use the flat end of a spudger to disconnect the rear-facing camera connector.
  33. iPhone 7 Lightning Connector Assembly Replacement: step 33, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 33, image 2 of 2
    • Remove the following Phillips screws securing the rear camera bracket to the rear case:
    • One 1.3 mm screw
    • One 2.5 mm screw
  34. iPhone 7 Lightning Connector Assembly Replacement: step 34, image 1 of 1
    • Remove the bracket.
  35. iPhone 7 Lightning Connector Assembly Replacement: step 35, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 35, image 2 of 2
    • Use the pointed end of a spudger to pry up and disconnect the antenna bus connector, just left of the rear camera module.
  36. iPhone 7 Lightning Connector Assembly Replacement: step 36, image 1 of 1
    • Remove the two 1.2 mm tri-point screws securing the upper cable bracket.
  37. iPhone 7 Lightning Connector Assembly Replacement: step 37, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 37, image 2 of 2
    • Remove the upper cable bracket.
  38. iPhone 7 Lightning Connector Assembly Replacement: step 38, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 38, image 2 of 2
    • Use the flat end of a spudger to disconnect the upper cable connector.
  39. iPhone 7 Lightning Connector Assembly Replacement: step 39, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 39, image 2 of 2
    • Remove the four Phillips screws securing the Wi-Fi antenna:
    • Three 1.2 mm screws
    • One 1.7 mm screw
  40. iPhone 7 Lightning Connector Assembly Replacement: step 40, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 40, image 2 of 2
    • Remove the top left antenna.
  41. iPhone 7 Lightning Connector Assembly Replacement: step 41, image 1 of 1
    • Remove the following Phillips screws:
    • One 1.3 mm screw
    • One 2.2 mm screw
  42. iPhone 7 Lightning Connector Assembly Replacement: step 42, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 42, image 2 of 2
  43. iPhone 7 Lightning Connector Assembly Replacement: step 43, image 1 of 1
    Standoff Screwdriver for iPhones
    $5.49
    Buy
    • Remove the 2.2 mm standoff screw from the grounding bracket.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  44. iPhone 7 Lightning Connector Assembly Replacement: step 44, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 44, image 2 of 2
    Buy
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
  45. iPhone 7 Lightning Connector Assembly Replacement, Lightning Connector Assembly: step 45, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement, Lightning Connector Assembly: step 45, image 2 of 2
    • Use the point of a spudger to disconnect the lower cable connector.
  46. iPhone 7 Lightning Connector Assembly Replacement: step 46, image 1 of 1
    • Remove the following screws:
    • One 1.4 mm Phillips screw
    • Three 2.2 mm standoff screws
    • Standoff screws are best removed using an [linked product missing or disabled: IF145-343] and driver handle.
  47. iPhone 7 Lightning Connector Assembly Replacement: step 47, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 47, image 2 of 2
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
  48. iPhone 7 Lightning Connector Assembly Replacement: step 48, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 48, image 2 of 2
    • Use the flat end of a spudger to gently lift the battery connector end of the logic board up.
    • Make sure you're not pulling against any cables. If you feel resistance, check all cables, connectors, and components are clear of the board.
  49. iPhone 7 Lightning Connector Assembly Replacement: step 49, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 49, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 49, image 3 of 3
    • Lift the battery connector end of the logic board and pull it up and out of the rear case.
    • Be careful not to snag the logic board on any cables.
  50. iPhone 7 Lightning Connector Assembly Replacement: step 50, image 1 of 1
    • Remove the 2.9 mm Phillips screw from the lightning connector.
  51. iPhone 7 Lightning Connector Assembly Replacement: step 51, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 51, image 2 of 2
    • Remove the spring contact from the lightning connector.
  52. iPhone 7 Lightning Connector Assembly Replacement: step 52, image 1 of 1
    • Remove the two 1.6 mm Phillips screws securing the lightning connector cable in place.
  53. iPhone 7 Lightning Connector Assembly Replacement: step 53, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 53, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 53, image 3 of 3
    • Remove the two stickers covering the screws that secure the lightning connector to the bottom of the rear case.
  54. iPhone 7 Lightning Connector Assembly Replacement: step 54, image 1 of 1
    • Remove the two 1.3 mm Phillips screws from the rear case.
  55. iPhone 7 Lightning Connector Assembly Replacement: step 55, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 55, image 2 of 2
    • Use the pointed end of a spudger to separate the two microphones from the bottom of the rear case.
  56. iPhone 7 Lightning Connector Assembly Replacement: step 56, image 1 of 1
    • Heating the lower edge of the iPhone will help soften the adhesive securing Lightning connector cable, making it easier to remove.
    • Use a hairdryer or reheat your iOpener to heat the lower edge of the phone.
    • Wait for about a minute, allowing the adhesive to warm up before proceeding to the next step.
  57. iPhone 7 Lightning Connector Assembly Replacement: step 57, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 57, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 57, image 3 of 3
    • Starting from the middle of the phone, slide an opening pick underneath the lightning connector to separate it from the rear case.
  58. iPhone 7 Lightning Connector Assembly Replacement: step 58, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 58, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 58, image 3 of 3
    • Continue to slide the pick towards the lightning connector to further separate the assembly from the rear case.
  59. iPhone 7 Lightning Connector Assembly Replacement: step 59, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 59, image 2 of 2
    • Continue to slide the pick underneath the lightning connecter assembly.
    • Stop sliding the pick once it passes the battery.
  60. iPhone 7 Lightning Connector Assembly Replacement: step 60, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 60, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 60, image 3 of 3
    • Starting at the corner of the phone, slide the pick underneath the assembly towards the lightning connector.
    • Stop sliding the pick when it is reaches the lightning connector.
  61. iPhone 7 Lightning Connector Assembly Replacement: step 61, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 61, image 2 of 2
    • Gently pull the lightning connector out of its hole on the rear case.
  62. iPhone 7 Lightning Connector Assembly Replacement: step 62, image 1 of 2 iPhone 7 Lightning Connector Assembly Replacement: step 62, image 2 of 2
    • Slide a pick below the lightning connector to further separate the lightning connector assembly from the rear case.
    • Continue to slide the pick until the lightning connector assembly is no longer adhered to the rear case.
  63. iPhone 7 Lightning Connector Assembly Replacement: step 63, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 63, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 63, image 3 of 3
    • Remove the lightning connector assembly.
    • Before installing or replacing the Lightning connector assembly:
    • Use a plastic tool to scour any bits of adhesive residue from the rear case.
    • Make sure the Lightning connector assembly is correctly positioned so that the two white dots on the iPhone's rear case show through the two circular cutouts in the Lightning flex cable. If they don't, the flex cable will remain misaligned and you won't be able to reconnect it to its socket on the logic board.
  64. iPhone 7 Lightning Connector Assembly Replacement: step 64, image 1 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 64, image 2 of 3 iPhone 7 Lightning Connector Assembly Replacement: step 64, image 3 of 3
    • A rubber gasket on the bottom of the Lightning connector protects your iPhone from liquid and dust intrusion. If you are installing a new Lightning connector assembly, you may need to carefully remove and transfer the gasket to the new part.
    • The small adhesive patch on the bottom of each microphone also protects your iPhone from liquid and dust intrusion. For best results, replace the two adhesive patches before installing your Lightning connector assembly.
Scott Havard
49,720 Reputation
31 Guides authored
Past 24 Hours: 43
Past 7 Days: 403
Past 30 Days: 1,982
All Time: 424,811
