iPhone 7 LCD Shield Plate Replacement
  1. iPhone 7 LCD Shield Plate Replacement, Pentalobe Screws: step 1, image 1 of 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 LCD Shield Plate Replacement, iPhone 7 Opening Procedure: step 2, image 1 of 1
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. iPhone 7 LCD Shield Plate Replacement: step 3, image 1 of 2 iPhone 7 LCD Shield Plate Replacement: step 3, image 2 of 2
    • Attach a suction cup to the lower half of the display assembly, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 7 LCD Shield Plate Replacement: step 4, image 1 of 3 iPhone 7 LCD Shield Plate Replacement: step 4, image 2 of 3 iPhone 7 LCD Shield Plate Replacement: step 4, image 3 of 3
    • Pull up on the suction cup to create a small gap between the display assembly and the rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong, and creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
  5. iPhone 7 LCD Shield Plate Replacement: step 5, image 1 of 3 iPhone 7 LCD Shield Plate Replacement: step 5, image 2 of 3 iPhone 7 LCD Shield Plate Replacement: step 5, image 3 of 3
    • Slide the spudger to the left along the lower edge of the iPhone.
    • Twist the spudger to widen the gap between the display and rear case.
  6. iPhone 7 LCD Shield Plate Replacement: step 6, image 1 of 3 iPhone 7 LCD Shield Plate Replacement: step 6, image 2 of 3 iPhone 7 LCD Shield Plate Replacement: step 6, image 3 of 3
    • Slide the spudger up the left side of the iPhone, starting at the lower edge and moving towards the volume control buttons and silent switch.
    • Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display.
  7. iPhone 7 LCD Shield Plate Replacement: step 7, image 1 of 3 iPhone 7 LCD Shield Plate Replacement: step 7, image 2 of 3 iPhone 7 LCD Shield Plate Replacement: step 7, image 3 of 3
    • Insert the flat edge of a spudger into the bottom right corner of the device.
    • Twist the spudger to widen the gap between the display assembly and the rear case.
    • Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
    • Do not insert the spudger further than the adhesive to avoid damaging delicate ribbon cables along the right edge.
  8. iPhone 7 LCD Shield Plate Replacement: step 8, image 1 of 2 iPhone 7 LCD Shield Plate Replacement: step 8, image 2 of 2
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10º as there are ribbon cables along the right edge of the device connecting the display to the logic board.
  9. iPhone 7 LCD Shield Plate Replacement: step 9, image 1 of 1
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  10. iPhone 7 LCD Shield Plate Replacement: step 10, image 1 of 2 iPhone 7 LCD Shield Plate Replacement: step 10, image 2 of 2
    • Slide an opening pick along the top edge of the iPhone, between the rear case and front panel, to break up the remaining adhesive holding the screen in place.
    • Be careful not to damage the plastic clips on the top edge of the phone.
  11. iPhone 7 LCD Shield Plate Replacement: step 11, image 1 of 3 iPhone 7 LCD Shield Plate Replacement: step 11, image 2 of 3 iPhone 7 LCD Shield Plate Replacement: step 11, image 3 of 3
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  12. iPhone 7 LCD Shield Plate Replacement, Battery Disconnection: step 12, image 1 of 1
    Tool used on this step:
    Tri-point Y000 Screwdriver
    $5.99
    Buy
  13. iPhone 7 LCD Shield Plate Replacement: step 13, image 1 of 1
    • Remove the lower connector bracket.
  14. iPhone 7 LCD Shield Plate Replacement: step 14, image 1 of 3 iPhone 7 LCD Shield Plate Replacement: step 14, image 2 of 3 iPhone 7 LCD Shield Plate Replacement: step 14, image 3 of 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  15. iPhone 7 LCD Shield Plate Replacement, Display Assembly: step 15, image 1 of 3 iPhone 7 LCD Shield Plate Replacement, Display Assembly: step 15, image 2 of 3 iPhone 7 LCD Shield Plate Replacement, Display Assembly: step 15, image 3 of 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  16. iPhone 7 LCD Shield Plate Replacement: step 16, image 1 of 3 iPhone 7 LCD Shield Plate Replacement: step 16, image 2 of 3 iPhone 7 LCD Shield Plate Replacement: step 16, image 3 of 3
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
  17. iPhone 7 LCD Shield Plate Replacement: step 17, image 1 of 2 iPhone 7 LCD Shield Plate Replacement: step 17, image 2 of 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  18. iPhone 7 LCD Shield Plate Replacement: step 18, image 1 of 1
  19. iPhone 7 LCD Shield Plate Replacement, Home/Touch ID Sensor: step 19, image 1 of 1
    • Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
    • One 1.1 mm screw
    • Three 1.3 mm screws
    • During reassembly, be careful not to overtighten these screws, or your home button may not work.
  20. iPhone 7 LCD Shield Plate Replacement: step 20, image 1 of 1
    • Remove the bracket that secures the home/Touch ID sensor.
  21. iPhone 7 LCD Shield Plate Replacement: step 21, image 1 of 3 iPhone 7 LCD Shield Plate Replacement: step 21, image 2 of 3 iPhone 7 LCD Shield Plate Replacement: step 21, image 3 of 3
  22. iPhone 7 LCD Shield Plate Replacement: step 22, image 1 of 2 iPhone 7 LCD Shield Plate Replacement: step 22, image 2 of 2
    • Carefully pry up the underlying connector and move it out of the way of the home/Touch ID cable.
    • It's very easy to damage your iPhone during this step. Work slowly and take care where you pry with your tool. If you damage the Touch ID hardware, it can only be replaced by Apple.
    • If the connector doesn't pry up easily, use a hair dryer or iOpener to heat and soften the adhesive securing the connector, and then try again.
    • Don't try to detach the connector completely—simply flip it up slightly so that the underlying home/Touch ID sensor cable can be removed.
  23. iPhone 7 LCD Shield Plate Replacement: step 23, image 1 of 1
    • Heating the area around the home/Touch ID sensor will help soften the adhesive holding its delicate cable in place, making it easier to remove safely.
    • Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
  24. iPhone 7 LCD Shield Plate Replacement: step 24, image 1 of 3 iPhone 7 LCD Shield Plate Replacement: step 24, image 2 of 3 iPhone 7 LCD Shield Plate Replacement: step 24, image 3 of 3
    • Use an opening pick to gently separate the adhesive holding the home/Touch ID sensor cable to the back side of the display panel.
  25. iPhone 7 LCD Shield Plate Replacement: step 25, image 1 of 1
    • Remove the home/Touch ID sensor assembly by lifting it through the front side of the display.
    • To reinstall, first feed the cable through the hole in the front of the display.
    • Your replacement part may come with an extra Y000 screw already installed right of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
    • Follow this guide to install replacement display adhesive on your screen.
  26. iPhone 7 LCD Shield Plate Replacement, Earpiece Speaker: step 26, image 1 of 1
    • Remove the three Phillips screws securing the earpiece bracket to the front panel:
    • Two 2.6 mm screws
    • One 1.7 mm screw
  27. iPhone 7 LCD Shield Plate Replacement: step 27, image 1 of 1
    • Remove the earpiece speaker bracket.
  28. iPhone 7 LCD Shield Plate Replacement: step 28, image 1 of 2 iPhone 7 LCD Shield Plate Replacement: step 28, image 2 of 2
    • Lift the front facing camera out of the way to access the earpiece speaker.
  29. iPhone 7 LCD Shield Plate Replacement: step 29, image 1 of 1
    • Remove the two Phillips screws securing the earpiece speaker to the front panel:
    • One 1.9 mm screw
    • One 2.5 mm screw
  30. iPhone 7 LCD Shield Plate Replacement: step 30, image 1 of 1
    • Remove the earpiece speaker.
  31. iPhone 7 LCD Shield Plate Replacement, Front Camera and Sensor Cable: step 31, image 1 of 1
    • Reheat your iOpener and apply it to the upper edge of the display assembly to soften the adhesive holding the front camera and sensor assembly in place.
    • Wait about two minutes before moving on to the next step to adequately soften the adhesive.
  32. iPhone 7 LCD Shield Plate Replacement: step 32, image 1 of 2 iPhone 7 LCD Shield Plate Replacement: step 32, image 2 of 2
    • Use a spudger to gently pry the ambient light sensor out of its recess on the front panel.
    • Try to get your tool all the way under the sensor to pry it away from the clear plastic beneath. If you pry only against the cable, the sensor may separate from the cable assembly and will need replacement. If you're replacing the sensor/cable assembly anyway, then it doesn't matter.
  33. iPhone 7 LCD Shield Plate Replacement: step 33, image 1 of 3 iPhone 7 LCD Shield Plate Replacement: step 33, image 2 of 3 iPhone 7 LCD Shield Plate Replacement: step 33, image 3 of 3
    • Slide the pick towards the front facing camera housing, separating the adhesive holding the cable to the front panel. Stop just before the screw posts.
  34. iPhone 7 LCD Shield Plate Replacement: step 34, image 1 of 3 iPhone 7 LCD Shield Plate Replacement: step 34, image 2 of 3 iPhone 7 LCD Shield Plate Replacement: step 34, image 3 of 3
    • Use the pick to lift the camera cable up off of the two plastic posts on the front panel and separate it from the last of the adhesive.
  35. iPhone 7 LCD Shield Plate Replacement: step 35, image 1 of 1
    • Remove the front camera and sensor cable.
  36. iPhone 7 LCD Shield Plate Replacement, LCD Shield Plate: step 36, image 1 of 2 iPhone 7 LCD Shield Plate Replacement, LCD Shield Plate: step 36, image 2 of 2
    • Remove the three 1.2mm tri-point Y000 screws from either side of the display assembly for a total of six screws.
  37. iPhone 7 LCD Shield Plate Replacement: step 37, image 1 of 1
    • Heat an iOpener and lay it over the edge of the shield closest to the home button to soften the adhesive holding it in place.
  38. iPhone 7 LCD Shield Plate Replacement: step 38, image 1 of 3 iPhone 7 LCD Shield Plate Replacement: step 38, image 2 of 3 iPhone 7 LCD Shield Plate Replacement: step 38, image 3 of 3
    • Use an opening pick to break up the adhesive near the home button that holds the LCD shield plate to the display assembly.
  39. iPhone 7 LCD Shield Plate Replacement: step 39, image 1 of 2 iPhone 7 LCD Shield Plate Replacement: step 39, image 2 of 2
    • Gently lift the LCD shield plate from the display assembly.
    • Be careful not to snag the display data cables when removing the LCD shield plate.
Evan Noronha
223,648 Reputation
168 Guides authored
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 206
All Time: 74,647
