iPhone 7 Display Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 7 Display Assembly Replacement, Display Assembly: step 1, image 1 of 3 iPhone 7 Display Assembly Replacement, Display Assembly: step 1, image 2 of 3 iPhone 7 Display Assembly Replacement, Display Assembly: step 1, image 3 of 3
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  2. iPhone 7 Display Assembly Replacement: step 2, image 1 of 3 iPhone 7 Display Assembly Replacement: step 2, image 2 of 3 iPhone 7 Display Assembly Replacement: step 2, image 3 of 3
    • Remove the two 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
    • Remove the bracket.
  3. iPhone 7 Display Assembly Replacement: step 3, image 1 of 2 iPhone 7 Display Assembly Replacement: step 3, image 2 of 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  4. iPhone 7 Display Assembly Replacement: step 4, image 1 of 1
Evan Noronha
223,653 Reputation
168 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 2,665
