iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement
  1. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement, Opening Procedure: step 1, image 1 of 1
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  2. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 2, image 1 of 1
    • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  3. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 3, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 3, image 2 of 2
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
  4. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 4, image 1 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 4, image 2 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 4, image 3 of 3
    • The safest place to pry from is the notch in the front panel above the headphone jack.
    • While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
  5. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 5, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 5, image 2 of 2
    • Twist the spudger to widen the gap between the front panel and the rear case.
  6. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 6, image 1 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 6, image 2 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 6, image 3 of 3
    • While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
  7. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 7, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 7, image 2 of 2
    • Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
  8. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 8, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 8, image 2 of 2
    • Insert the flat tip of the spudger under the right edge of the display.
    • Slide the spudger up the right side.
  9. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 9, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 9, image 2 of 2
    • Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
    • Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
  10. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 10, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 10, image 2 of 2
    • Pull up on the small nub on the suction cup to remove it from the display.
  11. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 11, image 1 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 11, image 2 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 11, image 3 of 3
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to support the display.
  12. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement, Battery Connector: step 12, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
    • One 2.9 mm screw
    • One 2.3 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  13. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 13, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 13, image 2 of 2
    • Remove the battery connector bracket.
  14. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 14, image 1 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 14, image 2 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 14, image 3 of 3
    • Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
  15. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 15, image 1 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 15, image 2 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 15, image 3 of 3
    • Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
  16. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement, Display Assembly: step 16, image 1 of 1
    • Remove the following Phillips screws:
    • Three 1.3 mm screws
    • One 1.6 mm screw
    • One 3.0 mm screw
    • During reassembly, it's critical to place this 3.0 mm screw in the top-right corner of the bracket. Placing it anywhere else may damage the logic board.
  17. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 17, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 17, image 2 of 2
    • Remove the display cable bracket.
  18. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 18, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 18, image 2 of 2
    • Be careful to only pry up on the connector itself and not the socket on the logic board.
    • Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
  19. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 19, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 19, image 2 of 2
    • Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  20. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 20, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 20, image 2 of 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
  21. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 21, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 21, image 2 of 2
  22. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement, iSight Camera: step 22, image 1 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement, iSight Camera: step 22, image 2 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement, iSight Camera: step 22, image 3 of 3
    • Peel up any tape covering the iSight camera bracket screws.
  23. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 23, image 1 of 1
    • Remove the following Phillips screws over the camera bracket:
    • One 1.9 mm screw
    • One 2.4 mm screw
  24. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 24, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 24, image 2 of 2
    • Remove the iSight camera bracket.
  25. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 25, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 25, image 2 of 2
    • Disconnect the iSight camera connector from its socket on the logic board.
    • Be sure to pry up only the connector and not the socket on the logic board.
  26. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 26, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 26, image 2 of 2
    • Insert the flat end of the spudger between the iSight camera and rear casing.
    • Gently pry the camera out from its housing.
  27. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 27, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 27, image 2 of 2
    • Remove the iSight camera.
  28. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement, SIM Tray: step 28, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement, SIM Tray: step 28, image 2 of 2
    • Insert a SIM eject tool into the hole in the SIM tray.
    • Press to eject the SIM tray.
  29. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 29, image 1 of 1
    • Remove the SIM tray.
    • When reinserting the SIM tray, be sure to orient the tray such that the SIM eject hole is on the bottom.
  30. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement, Logic Board: step 30, image 1 of 1
    • Remove the single 1.4 mm Phillips screw holding the NFC bracket in place.
  31. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 31, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 31, image 2 of 2
    • Remove the NFC bracket.
  32. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 32, image 1 of 1
    • Remove the two 2.7 mm Phillips screws securing the audio control cable bracket to the logic board.
  33. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 33, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 33, image 2 of 2
    • Remove the audio control cable bracket.
  34. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 34, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 34, image 2 of 2
    • Disconnect the audio control cable by prying its connector straight up from its socket on the logic board.
  35. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 35, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 35, image 2 of 2
    • Disconnect the cellular antenna cable by prying its connector straight up from its respective socket on the logic board.
  36. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 36, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 36, image 2 of 2
    • Disconnect the Wi-Fi diversity antenna cable by prying its connector up from the logic board.
  37. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 37, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 37, image 2 of 2
    • Disconnect the power button flex cable from its socket on the logic board.
  38. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 38, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 38, image 2 of 2
    • Disconnect the antenna cable by prying it up from the logic board.
  39. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 39, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 39, image 2 of 2
    • Use the flat end of a spudger to disconnect the Lightning connector flex cable from the logic board.
  40. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 40, image 1 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 40, image 2 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 40, image 3 of 3
    • Deroute the antenna cable from the two clips on the right edge of the logic board.
  41. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 41, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 41, image 2 of 2
    Standoff Screwdriver for iPhones
    $5.49
    Buy
    • Remove the following screws:
    • One 1.3 mm Phillips screw
    • One 2.6 mm Phillips screw
    • One 2.2 mm standoff screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  42. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 42, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 42, image 2 of 2
    • Remove the bracket.
  43. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 43, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 43, image 2 of 2
    • Deroute the upper left cellular antenna cable from the first logic board clip by nudging it out from under the clip, towards the battery.
  44. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 44, image 1 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 44, image 2 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 44, image 3 of 3
    • Continue derouting the cellular antenna cable from the second and third logic board clips.
    • Use the pointed tip of a spudger to gently pry the cellular antenna cable from the middle logic board clip.
    • Don't try to remove it by pulling on the cable, as it will tear easily.
    • In order for the cable to reach its socket on the logic board, you must route it above the logic board and underneath the audio control flex cable, as shown in the first photo.
  45. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 45, image 1 of 1
    • Remove the final 2.0 mm Phillips screw directly below the SIM card reader.
  46. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 46, image 1 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 46, image 2 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 46, image 3 of 3
    • Carefully raise—but do not remove—the logic board, lifting it from the bottom edge nearest the Lightning connector.
  47. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 47, image 1 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 47, image 2 of 3 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 47, image 3 of 3
    • Tip the logic board up to a vertical position to expose the single antenna connector on the underside, near the top edge of the board.
    • Do not attempt to fully remove the logic board yet, as the Wi-Fi/Bluetooth antenna is still connected to the underside of the board.
  48. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 48, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 48, image 2 of 2
    • Gently lay the logic board upside-down, with the top portion resting against the rear case of the iPhone.
    • Use the flat end of the spudger to disconnect the Wi-Fi/Bluetooth antenna cable from its socket on the back of the logic board.
  49. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 49, image 1 of 1
    • Remove the logic board.
  50. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement, Wi-Fi/Bluetooth Antenna: step 50, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement, Wi-Fi/Bluetooth Antenna: step 50, image 2 of 2
    • Remove the sticker over the third screw holding the cellular antenna in place.
  51. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 51, image 1 of 1
    • Remove the following three Phillips screws holding the cellular antenna in place:
    • One 2.7 mm screw
    • One 1.7 mm screw
    • One 1.3 mm screw
  52. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 52, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 52, image 2 of 2
    • Remove the cellular antenna.
  53. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 53, image 1 of 1
    • Remove the single 1.3 mm Phillips screw securing the antenna to the rear case.
  54. iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 54, image 1 of 2 iPhone 6s Plus Wi-Fi/Bluetooth Antenna Replacement: step 54, image 2 of 2
    • Remove the Wi-Fi/Bluetooth antenna.
Evan Noronha
223,648 Reputation
168 Guides authored
Past 24 Hours: 6
Past 7 Days: 49
Past 30 Days: 212
All Time: 80,887
