iPhone 6s Plus LCD and Digitizer Replacement
  1. iPhone 6s Plus LCD and Digitizer Replacement, Pentalobe Screws: step 1, image 1 of 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws on either side of the Lightning port.
  2. iPhone 6s Plus LCD and Digitizer Replacement, Taping Over The Display: step 2, image 1 of 3 iPhone 6s Plus LCD and Digitizer Replacement, Taping Over The Display: step 2, image 2 of 3 iPhone 6s Plus LCD and Digitizer Replacement, Taping Over The Display: step 2, image 3 of 3
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
  3. iPhone 6s Plus LCD and Digitizer Replacement, Opening Procedure: step 3, image 1 of 1
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • If you don't have an Anti-Clamp, follow the next three steps to use a suction handle.
    • Apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  4. iPhone 6s Plus LCD and Digitizer Replacement: step 4, image 1 of 1
    • Opening the display on the 6s Plus separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  5. iPhone 6s Plus LCD and Digitizer Replacement: step 5, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 5, image 2 of 2
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
  6. iPhone 6s Plus LCD and Digitizer Replacement: step 6, image 1 of 3 iPhone 6s Plus LCD and Digitizer Replacement: step 6, image 2 of 3 iPhone 6s Plus LCD and Digitizer Replacement: step 6, image 3 of 3
    • The safest place to pry from is the notch in the front panel above the headphone jack.
    • While still maintaining pressure on the suction cup, insert the flat tip of a spudger into the gap, directly above the headphone jack.
  7. iPhone 6s Plus LCD and Digitizer Replacement: step 7, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 7, image 2 of 2
    • Twist the spudger to widen the gap between the front panel and the rear case.
  8. iPhone 6s Plus LCD and Digitizer Replacement: step 8, image 1 of 3 iPhone 6s Plus LCD and Digitizer Replacement: step 8, image 2 of 3 iPhone 6s Plus LCD and Digitizer Replacement: step 8, image 3 of 3
    • While firmly pulling up on the suction cup, slide the edge of the spudger under the bottom left corner of the display.
  9. iPhone 6s Plus LCD and Digitizer Replacement: step 9, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 9, image 2 of 2
    • Slide the tip of the spudger up the left side of the phone, between the front panel and the rear case.
  10. iPhone 6s Plus LCD and Digitizer Replacement: step 10, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 10, image 2 of 2
    • Insert the flat tip of the spudger under the right edge of the display.
    • Slide the spudger up the right side.
  11. iPhone 6s Plus LCD and Digitizer Replacement: step 11, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 11, image 2 of 2
    • Use a plastic opening tool to hold down the rear case while pulling up the suction cup to open the phone.
    • Do not remove the display completely, or you will damage the data cables connecting the display near the top edge of the iPhone.
  12. iPhone 6s Plus LCD and Digitizer Replacement: step 12, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 12, image 2 of 2
    • Pull up on the small nub on the suction cup to remove it from the display.
  13. iPhone 6s Plus LCD and Digitizer Replacement: step 13, image 1 of 3 iPhone 6s Plus LCD and Digitizer Replacement: step 13, image 2 of 3 iPhone 6s Plus LCD and Digitizer Replacement: step 13, image 3 of 3
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Don't open the display more than 90º—it is still connected to the top of the phone by the display, digitizer, and front camera cables which can tear easily.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to support the display.
  14. iPhone 6s Plus LCD and Digitizer Replacement, Battery Connector: step 14, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Remove two Phillips screws securing the battery connector bracket to the logic board, of the following lengths:
    • One 2.9 mm screw
    • One 2.3 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  15. iPhone 6s Plus LCD and Digitizer Replacement: step 15, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 15, image 2 of 2
    • Remove the battery connector bracket.
  16. iPhone 6s Plus LCD and Digitizer Replacement: step 16, image 1 of 3 iPhone 6s Plus LCD and Digitizer Replacement: step 16, image 2 of 3 iPhone 6s Plus LCD and Digitizer Replacement: step 16, image 3 of 3
    • Use a spudger or a clean fingernail to disconnect the battery connector by prying it straight up off the logic board.
  17. iPhone 6s Plus LCD and Digitizer Replacement: step 17, image 1 of 3 iPhone 6s Plus LCD and Digitizer Replacement: step 17, image 2 of 3 iPhone 6s Plus LCD and Digitizer Replacement: step 17, image 3 of 3
    • Bend the connector back to ensure it doesn't make contact and power the iPhone on while you're working on it.
  18. iPhone 6s Plus LCD and Digitizer Replacement, Display Assembly: step 18, image 1 of 1
    • Remove the following Phillips screws:
    • Three 1.3 mm screws
    • One 1.6 mm screw
    • One 3.0 mm screw
    • During reassembly, it's critical to place this 3.0 mm screw in the top-right corner of the bracket. Placing it anywhere else may damage the logic board.
  19. iPhone 6s Plus LCD and Digitizer Replacement: step 19, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 19, image 2 of 2
    • Remove the display cable bracket.
  20. iPhone 6s Plus LCD and Digitizer Replacement: step 20, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 20, image 2 of 2
    • Be careful to only pry up on the connector itself and not the socket on the logic board.
    • Use a plastic opening tool to disconnect the front-facing camera and sensor cable connector.
  21. iPhone 6s Plus LCD and Digitizer Replacement: step 21, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 21, image 2 of 2
    • Use a plastic opening tool to disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  22. iPhone 6s Plus LCD and Digitizer Replacement: step 22, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 22, image 2 of 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the home button/fingerprint sensor cable by prying it straight up from its socket on the logic board.
  23. iPhone 6s Plus LCD and Digitizer Replacement: step 23, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 23, image 2 of 2
  24. iPhone 6s Plus LCD and Digitizer Replacement, Home Button Assembly: step 24, image 1 of 1
    • Remove the two 1.9 mm Phillips screws securing the home button bracket.
  25. iPhone 6s Plus LCD and Digitizer Replacement: step 25, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 25, image 2 of 2
    • Remove the home button bracket.
  26. iPhone 6s Plus LCD and Digitizer Replacement: step 26, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 26, image 2 of 2
    • Use the pointed tip of a spudger to disconnect the home button cable from its connector on the display assembly.
  27. iPhone 6s Plus LCD and Digitizer Replacement: step 27, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 27, image 2 of 2
    iOpener
    $19.99
    Buy
    • The rubber gasket surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button gasket.
    • Using your fingertip, gently press up on the home button from the front side of the display assembly. Use firm, constant pressure to slowly separate the home button's rubber gasket from the front panel.
  28. iPhone 6s Plus LCD and Digitizer Replacement: step 28, image 1 of 3 iPhone 6s Plus LCD and Digitizer Replacement: step 28, image 2 of 3 iPhone 6s Plus LCD and Digitizer Replacement: step 28, image 3 of 3
    • Use the pointed end of a spudger to pry the lightly-adhered home button flex cable off the display assembly.
  29. iPhone 6s Plus LCD and Digitizer Replacement: step 29, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 29, image 2 of 2
    • Remove the home button assembly.
  30. iPhone 6s Plus LCD and Digitizer Replacement, Earpiece Speaker: step 30, image 1 of 1
    • Remove the following three Phillips screws:
    • Two 2.7 mm screws
    • One 1.4 mm screw
  31. iPhone 6s Plus LCD and Digitizer Replacement: step 31, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 31, image 2 of 2
    • Remove the earpiece speaker bracket.
  32. iPhone 6s Plus LCD and Digitizer Replacement: step 32, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 32, image 2 of 2
    • Use the flat end of a spudger to lift the FaceTime camera out of its housing.
  33. iPhone 6s Plus LCD and Digitizer Replacement: step 33, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 33, image 2 of 2
    • Pull the FaceTime camera back and remove the earpiece speaker.
  34. iPhone 6s Plus LCD and Digitizer Replacement, FaceTime Camera and Sensor Assembly: step 34, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement, FaceTime Camera and Sensor Assembly: step 34, image 2 of 2
    • Use the pointed tip of a spudger to lift the ambient light sensor from its housing in the front panel.
  35. iPhone 6s Plus LCD and Digitizer Replacement: step 35, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 35, image 2 of 2
    • Insert the pointed tip of a spudger between the microphone flex cable and the front panel to break the adhesive holding it in place.
  36. iPhone 6s Plus LCD and Digitizer Replacement: step 36, image 1 of 3 iPhone 6s Plus LCD and Digitizer Replacement: step 36, image 2 of 3 iPhone 6s Plus LCD and Digitizer Replacement: step 36, image 3 of 3
    • Use the flat tip of a spudger to lift up the microphone and earpiece gasket.
  37. iPhone 6s Plus LCD and Digitizer Replacement: step 37, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 37, image 2 of 2
    • Remove the FaceTime camera and sensor assembly.
  38. iPhone 6s Plus LCD and Digitizer Replacement, Display EMI Shield: step 38, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement, Display EMI Shield: step 38, image 2 of 2
    • Remove the seven 1.5 mm Phillips screws holding the display EMI shield in place.
    • The screw on the far right in the first photo is recessed about 1.8 cm from the edge of the display.
  39. iPhone 6s Plus LCD and Digitizer Replacement: step 39, image 1 of 2 iPhone 6s Plus LCD and Digitizer Replacement: step 39, image 2 of 2
    • Remove the EMI shield from the front panel.
  40. iPhone 6s Plus LCD and Digitizer Replacement, LCD and Digitizer: step 40, image 1 of 1
    • The LCD and digitizer remains.
    • The Touch ID function will ONLY work with your phone's original home button assembly, so you'll need to transfer the home button assembly from your old display assembly to your new display assembly to retain Touch ID.
    • After reassembly, clean the touchscreen surface with an alcohol wipe prior to turning the iPhone back on. The alcohol helps dissipate any lingering static electricity, which can cause problems with the display.
    • After reassembly, connect the iPhone to an AC power source before turning it on for the first time. Once the iPhone has booted up successfully, you can disconnect the AC power.
Evan Noronha
223,564 Reputation
168 Guides authored
Past 24 Hours: 2
Past 7 Days: 70
Past 30 Days: 281
All Time: 108,464
