iPhone 17 Pro USB-C Port Assembly Replacement
    1. iPhone 17 Pro USB-C Port Assembly Replacement, Safety precautions: step 1, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Safety precautions: step 1, image 2 of 2
      • Let your iPhone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone.
      • Hold the power and either volume button and slide to power off your phone.
      Ask FixBot
    2. iPhone 17 Pro USB-C Port Assembly Replacement, Cracked glass preparation: step 2, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Cracked glass preparation: step 2, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Cracked glass preparation: step 2, image 3 of 3
      Tool used on this step:
      iFixit Safety Glasses
      $7.95
      Buy
      • Glass shards can complicate disassembly—or worse, cause injury. If your phone is cracked, follow this step.
      • Apply strips of packing tape to the cracked glass until it's completely covered—this will help keep the glass contained and allow the suction cup to stick.
      • Make sure there's a single strip of tape (not overlapping) across the bottom edge, big enough for a suction cup to fit on.
      • Only cover the glass itself—don't stick any tape to the frame.
      • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
      Ask FixBot
    3. iPhone 17 Pro USB-C Port Assembly Replacement, Remove the pentalobe screws: step 3, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Remove the pentalobe screws: step 3, image 2 of 2
      • Use a P2 pentalobe screwdriver to remove the two 7.5 mm‑long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 17 Pro USB-C Port Assembly Replacement, Mark your opening picks: step 4, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Mark your opening picks: step 4, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Mark your opening picks: step 4, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • Alternatively, you can tape a coin 3 mm from the tip of the pick.
      Ask FixBot
    2. iPhone 17 Pro USB-C Port Assembly Replacement, Heat the bottom edge: step 5, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's slightly too hot to touch.
      • Improper use of a heat gun can destroy the display and/or battery—follow the linked instructions carefully.
      Ask FixBot
    3. iPhone 17 Pro USB-C Port Assembly Replacement, Apply a suction handle: step 6, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Apply a suction handle: step 6, image 2 of 2
      • Apply a suction handle to the bottom edge of the screen, as close to the edge as possible.
      Ask FixBot
    4. iPhone 17 Pro USB-C Port Assembly Replacement, Screen bezel information: step 7, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Screen bezel information: step 7, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Screen bezel information: step 7, image 3 of 3
      • During the next step, make sure you're inserting your pick in the correct location:
      • There's a plastic bezel on the underside of the screen that sits on the frame. Insert your pick here, making sure it's completely under the bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll separate the two, complicating the repair.
      Ask FixBot
    5. iPhone 17 Pro USB-C Port Assembly Replacement, Insert an opening pick: step 8, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Insert an opening pick: step 8, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Insert an opening pick: step 8, image 3 of 3
      • Pull up on the suction handle with strong, steady force until a gap forms between the screen and frame.
      • This may take significant force. If you're having trouble, reheat the screen and try again.
      • Insert the tip of an opening pick in the gap you just created.
      Ask FixBot
    6. iPhone 17 Pro USB-C Port Assembly Replacement, Screen information: step 9, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Screen information: step 9, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Screen information: step 9, image 3 of 3
      • Don't insert your pick more than 3 mm under the screen to avoid damaging the following components:
      • The screen and ambient light sensor cables are located near the volume and Action buttons.
      • There are delicate spring contacts around the perimeter of the phone.
      • The underside of the screen has thin, metal clips that go into corresponding slots on the frame.
      Ask FixBot
    7. iPhone 17 Pro USB-C Port Assembly Replacement, Separate the bottom edge adhesive: step 10, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Separate the bottom edge adhesive: step 10, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Separate the bottom edge adhesive: step 10, image 3 of 3
      • Slide the opening pick along the bottom edge to separate the adhesive.
      • Leave the pick inserted under the bottom right corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    8. iPhone 17 Pro USB-C Port Assembly Replacement, Remove the suction handle: step 11, image 1 of 1
      • Pull the small nub on the suction cup to remove it from the screen.
      Ask FixBot
    9. iPhone 17 Pro USB-C Port Assembly Replacement, Heat the right edge: step 12, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Heat the right edge: step 12, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Heat the right edge: step 12, image 3 of 3
      • Use a hair dryer or heat gun to heat the right edge of the screen until it's slightly too hot to touch.
      Ask FixBot
    10. iPhone 17 Pro USB-C Port Assembly Replacement, Separate the right edge adhesive: step 13, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Separate the right edge adhesive: step 13, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Separate the right edge adhesive: step 13, image 3 of 3
      • Insert a second opening pick under the bottom right corner of the screen.
      • Slide the pick up the right edge to separate the adhesive and release the two clips.
      • You may need to pry the screen up slightly to release the clips
      • Leave the pick inserted under the top right corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    11. iPhone 17 Pro USB-C Port Assembly Replacement, Heat the top edge: step 14, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Heat the top edge: step 14, image 2 of 2
      • Use a hair dryer or heat gun to heat the top edge of the screen until it's slightly too hot to touch.
      Ask FixBot
    12. iPhone 17 Pro USB-C Port Assembly Replacement, Separate the top edge adhesive: step 15, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Separate the top edge adhesive: step 15, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Separate the top edge adhesive: step 15, image 3 of 3
      • Insert a third opening pick under the top right corner of the screen.
      • Slide the pick along the top edge and just barely around the top left corner to separate the adhesive and release the two clips.
      • Don't slide the pick farther, or you may damage the ambient light sensor cable.
      • Leave the pick inserted under the top left corner to prevent the adhesive from re‑sealing.
      Ask FixBot
    13. iPhone 17 Pro USB-C Port Assembly Replacement, Heat the left edge: step 16, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Heat the left edge: step 16, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Heat the left edge: step 16, image 3 of 3
      • Use a hair dryer or heat gun to heat the left edge of the screen until it's slightly too hot to touch.
      Ask FixBot
    14. iPhone 17 Pro USB-C Port Assembly Replacement, Separate the left edge adhesive: step 17, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Separate the left edge adhesive: step 17, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Separate the left edge adhesive: step 17, image 3 of 3
      • Insert a fourth opening pick under the bottom left corner of the screen.
      • Slide the pick up the right edge to separate the adhesive and release the clip, stopping just before the volume up button.
      • You may need to pry up the screen slightly to release the clip.
      • Don't slide the pick farther, or you may damage the screen cable.
      Ask FixBot
    15. iPhone 17 Pro USB-C Port Assembly Replacement, Prop up the screen: step 18, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Prop up the screen: step 18, image 2 of 2
      • At this point, the screen should be completely detached from the frame. If it feels stuck, go back around the perimeter and separate any remaining adhesive or clips.
      • Lift the screen straight up and swing it over the left edge, propping it up against a sturdy box or stack of books so the cables aren't strained.
      • Alternatively, you can lay the screen down flat over the left side.
      Ask FixBot
    16. iPhone 17 Pro USB-C Port Assembly Replacement, Remove the cover screws: step 19, image 1 of 1
      FixMat
      $36.95
      Buy
      • Use a JIS 00 screwdriver to remove the two screws securing the cable covers:
      • One 1.4 mm‑long screw for the screen and front sensor cable cover
      • One 1.3 mm‑long screw for the battery cover
      • Small iFixit Phillips bits are designed to work with JIS screws. You can try Phillips drivers from other manufacturers, but you risk stripping the screw.
      Ask FixBot
    17. iPhone 17 Pro USB-C Port Assembly Replacement, Remove the covers: step 20, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Remove the covers: step 20, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Remove the covers: step 20, image 3 of 3
      • Remove the two covers.
      Ask FixBot
    18. iPhone 17 Pro USB-C Port Assembly Replacement, Disconnect the battery: step 21, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Disconnect the battery: step 21, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the battery press connector.
      Ask FixBot
    19. iPhone 17 Pro USB-C Port Assembly Replacement, Disconnect the screen: step 22, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Disconnect the screen: step 22, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Disconnect the screen: step 22, image 3 of 3
      • Use the tip of an opening pick or the point of a spudger to pry up and disconnect the screen and ambient light sensor press connectors.
      Ask FixBot
    20. iPhone 17 Pro USB-C Port Assembly Replacement, Remove the screen: step 23, image 1 of 1
      • Remove the screen.
      Ask FixBot
    1. iPhone 17 Pro USB-C Port Assembly Replacement, Remove the battery tray screws: step 24, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Remove the battery tray screws: step 24, image 2 of 2
      • Use a Torx Plus 4IP screwdriver to remove the screws securing the battery tray:
      • One 7.5 mm‑long screw
      • One 5.9 mm‑long screw
      • One 3.4 mm‑long screw
      • One 2.3 mm‑long screw
      • Nine 3.7 mm‑long screws
      • One 3.7 mm‑long screw
      • iPhone models with a physical SIM card won't have this screw.
      Ask FixBot
    2. iPhone 17 Pro USB-C Port Assembly Replacement, Remove the battery: step 25, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Remove the battery: step 25, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Remove the battery: step 25, image 3 of 3
      • Use your finger to lift the top left corner of the battery tray and remove it.
      • Be careful not to smudge the front camera.
      Ask FixBot
    1. iPhone 17 Pro USB-C Port Assembly Replacement, Separate the buffer strip: step 26, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Separate the buffer strip: step 26, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Separate the buffer strip: step 26, image 3 of 3
      • Slide the tip of an opening pick along the top edge of the Taptic Engine to separate the plastic buffer strip adhered to it.
      Ask FixBot
    2. iPhone 17 Pro USB-C Port Assembly Replacement, Remove the loudspeaker: step 27, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Remove the loudspeaker: step 27, image 2 of 2
      • Use a JIS 00 screwdriver to remove the six screws securing the loudspeaker:
      • Two 2.7 mm‑long screws
      • Two 2.0 mm‑long screws
      • One 1.5 mm‑long screw
      • One 1.5 mm‑long screw attached to the bottom edge
      Ask FixBot
    3. iPhone 17 Pro USB-C Port Assembly Replacement: step 28, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement: step 28, image 2 of 2
      • An adhesive gasket holds the loudspeaker to the frame.
      • Tilt the top edge of the loudspeaker out of its recess.
      • Slowly pull the loudspeaker away from the frame to release the adhesive.
      • Remove the loudspeaker.
      Ask FixBot
    1. iPhone 17 Pro USB-C Port Assembly Replacement, Remove the ground clip: step 29, image 1 of 1
      • Use a JIS 00 screwdriver to remove the two 2.0 mm‑long screws securing the ground clip.
      Ask FixBot
    2. iPhone 17 Pro USB-C Port Assembly Replacement: step 30, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement: step 30, image 2 of 2
      • Use tweezers to remove the ground clip.
      • The clip is delicate and easy to lose. Store it in a safe place for reassembly.
      Ask FixBot
    3. iPhone 17 Pro USB-C Port Assembly Replacement, Loosen the flex antenna: step 31, image 1 of 1
      • Use a JIS 00 screwdriver to remove the three 2.0 mm‑long screws securing the flex antenna.
      Ask FixBot
    4. iPhone 17 Pro USB-C Port Assembly Replacement: step 32, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement: step 32, image 2 of 2
      • Use your fingers or a spudger to swing the flex antenna out of the way to access the screws beneath it.
      Ask FixBot
    5. iPhone 17 Pro USB-C Port Assembly Replacement, Remove the Taptic Engine: step 33, image 1 of 1
      • Use a standoff screwdriver to remove the two 4.0 mm‑long screws securing the Taptic Engine.
      Ask FixBot
    6. iPhone 17 Pro USB-C Port Assembly Replacement: step 34, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 34, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 34, image 3 of 3
      • Use your fingers to flip the Taptic Engine out of its recess and onto the edge of the iPhone.
      • Hold onto the Taptic Engine during the next step to prevent straining its cable.
      Ask FixBot
    7. iPhone 17 Pro USB-C Port Assembly Replacement: step 35, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement: step 35, image 2 of 2
      • Use the point of a spudger to pry up the Taptic Engine press connector and disconnect it.
      Ask FixBot
    8. iPhone 17 Pro USB-C Port Assembly Replacement: step 36, image 1 of 1
      • Remove the Taptic Engine.
      Ask FixBot
    1. iPhone 17 Pro USB-C Port Assembly Replacement, Disconnect the lower microphone: step 37, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Disconnect the lower microphone: step 37, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the lower microphone connector.
      Ask FixBot
    2. iPhone 17 Pro USB-C Port Assembly Replacement: step 38, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement: step 38, image 2 of 2
      • Remove the two screws securing the lower microphone:
      • One 3.2 mm-long standoff screw
      • One 3.1 mm-long JIS 00 screw attached to the bottom edge of the iPhone frame
      Ask FixBot
    3. iPhone 17 Pro USB-C Port Assembly Replacement, Soften the adhesive gasket: step 39, image 1 of 1
      • The lower microphone is still attached to the frame by an adhesive gasket.
      • Use a hair dryer or an iOpener to heat the bottom-right corner of the iPhone until it's warm to the touch.
      Ask FixBot
    4. iPhone 17 Pro USB-C Port Assembly Replacement, Remove the lower microphone: step 40, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Remove the lower microphone: step 40, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Remove the lower microphone: step 40, image 3 of 3
      • Insert the point of an opening pick between the lower microphone and the frame.
      • Slide the pick along the edge to create a gap between the microphone and the frame.
      Ask FixBot
    5. iPhone 17 Pro USB-C Port Assembly Replacement: step 41, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 41, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 41, image 3 of 3
      • Insert the flat edge of a spudger into the gap between the lower microphone and the frame.
      • Twist the spudger slowly to pry the microphone off the frame.
      • Remove the lower microphone.
      Ask FixBot
    1. iPhone 17 Pro USB-C Port Assembly Replacement, Disconnect the USB-C port assembly: step 42, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Disconnect the USB-C port assembly: step 42, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Disconnect the USB-C port assembly: step 42, image 3 of 3
      • Use the point of a spudger to pry up and disconnect the two USB-C port assembly press connectors (one's underneath the other) from the bottom-left corner of the logic board.
      Ask FixBot
    2. iPhone 17 Pro USB-C Port Assembly Replacement, Remove the USB-C port assembly screws: step 43, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Remove the USB-C port assembly screws: step 43, image 2 of 2
      • Remove the screws securing the USB-C port assembly:
      • Three 1.5 mm‑long JIS 00 screws
      • Two 1.7 mm‑long JIS 00 screws
      • One 1.3 mm‑long JIS 00 screw
      • One 1.2 mm‑long tri-point Y000 screw
      • If your iPhone doesn't have mmWave functionality, you may not have this screw.
      Ask FixBot
    3. iPhone 17 Pro USB-C Port Assembly Replacement: step 44, image 1 of 1
      • Use a JIS 00 screwdriver to remove the 1.2 mm‑long screw securing the USB-C port assembly to the bottom left corner of the frame.
      Ask FixBot
    4. iPhone 17 Pro USB-C Port Assembly Replacement: step 45, image 1 of 1
      • Use a JIS 00 screwdriver to remove the two 3.3 mm‑long screws securing the USB-C port to the bottom edge of the frame.
      Ask FixBot
    5. iPhone 17 Pro USB-C Port Assembly Replacement: step 46, image 1 of 1
      • Use a JIS 00 screwdriver to remove the 1.2 mm‑long screw securing the USB-C port assembly to the right edge of the frame.
      Ask FixBot
    6. iPhone 17 Pro USB-C Port Assembly Replacement, Soften the USB-C assembly adhesive: step 47, image 1 of 1
      • Use a hair dryer or an iOpener to heat the entire USB-C port assembly until it's warm to the touch.
      Ask FixBot
    7. iPhone 17 Pro USB-C Port Assembly Replacement, Separate the microphone module: step 48, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Separate the microphone module: step 48, image 2 of 2
      • Slide the point of an opening pick between the microphone module (left of the USB-C port) and the bottom edge of the frame.
      • Pry gently to separate the microphone from the frame.
      Ask FixBot
    8. iPhone 17 Pro USB-C Port Assembly Replacement, Remove the USB-C port assembly: step 49, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Remove the USB-C port assembly: step 49, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Remove the USB-C port assembly: step 49, image 3 of 3
      • The large black graphite sheet inside the frame is delicate. Be very mindful not to tear it with your opening pick.
      • Slide the opening pick under the USB-C port assembly, near the center.
      • Slide the pick towards the right edge of the frame to separate the adhesive holding the assembly.
      Ask FixBot
    9. iPhone 17 Pro USB-C Port Assembly Replacement: step 50, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 50, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 50, image 3 of 3
      • Grab the USB-C port assembly with your fingers and slowly pull it away from the frame to remove it.
      • If the USB-C port assembly feels stuck, check for any missed screws and separate any remaining adhesive.
      Ask FixBot
    1. iPhone 17 Pro USB-C Port Assembly Replacement, Disassembly complete: step 51, image 1 of 1
      • Congratulations on completing disassembly! The remaining steps will show how to reassemble your iPhone.
      • Depending on your iPhone model, some reassembly photos may have minor visual discrepancies. The procedure, however, will be correct for your iPhone.
      Ask FixBot
    1. iPhone 17 Pro USB-C Port Assembly Replacement, Install the USB-C port assembly: step 52, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Install the USB-C port assembly: step 52, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Install the USB-C port assembly: step 52, image 3 of 3
      • Carefully inspect your replacement USB-C port assembly and remove any adhesive liners.
      • Align the assembly with the bottom edge of the frame and lay it loosely in place.
      • Make sure the assembly tucks below the black plastic speaker channel.
      Ask FixBot
    2. iPhone 17 Pro USB-C Port Assembly Replacement: step 53, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 53, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 53, image 3 of 3
      • The metal mounting tab near the top of the USB-C port assembly has a bend that has to sit underneath the logic board.
      • Tuck the metal mounting tab's bend underneath the logic board. When it's properly positioned, the mounting tab's screw hole should line up correctly.
      Ask FixBot
    3. iPhone 17 Pro USB-C Port Assembly Replacement: step 54, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement: step 54, image 2 of 2
      • Use a JIS 00 screwdriver to install the two 3.3 mm‑long USB-C port screws to the bottom edge of the frame.
      • Make sure to install these screws in the holes marked in green, not red.
      Ask FixBot
    4. iPhone 17 Pro USB-C Port Assembly Replacement: step 55, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement: step 55, image 2 of 2
      • Install the USB-C port assembly screws:
      • One 1.2 mm‑long Y000 screw
      Ask FixBot
    5. iPhone 17 Pro USB-C Port Assembly Replacement: step 56, image 1 of 1
      • Use a JIS 00 screwdriver to install the 1.2 mm‑long USB-C port assembly screw to the bottom left corner of the frame.
      Ask FixBot
    6. iPhone 17 Pro USB-C Port Assembly Replacement: step 57, image 1 of 1
      • Use a JIS 00 screwdriver to install the 1.2 mm‑long USB-C port assembly screw to the right edge of the frame.
      Ask FixBot
    7. iPhone 17 Pro USB-C Port Assembly Replacement: step 58, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 58, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 58, image 3 of 3
      Tesa 61395 Tape
      $2.95
      Buy
      • If the microphone adhesive gasket isn't deformed and your replacement USB-C port assembly didn't come with adhesive, you can reuse the existing gasket. Be aware that you'll lose water and dust resistance.
      • Use tweezers to remove the adhesive from where the microphone attaches to the frame.
      • You can use some double-sided tape as a replacement adhesive. Use a pin to poke a hole through the tape. Enlarge it enough for the mic hole, then apply the tape to the microphone.
      • Use your finger to align and press the microphone module onto the frame.
      Ask FixBot
    8. iPhone 17 Pro USB-C Port Assembly Replacement: step 59, image 1 of 1
      • Use a hair dryer or an iOpener to heat the entire USB-C port assembly until it's warm to the touch. This helps the adhesive to bond better.
      Ask FixBot
    9. iPhone 17 Pro USB-C Port Assembly Replacement: step 60, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement: step 60, image 2 of 2
      • Use your finger to press and connect the two USB-C port assembly press connectors (one's underneath the other) to the logic board.
      Ask FixBot
    1. iPhone 17 Pro USB-C Port Assembly Replacement, Remove the microphone adhesive gasket: step 61, image 1 of 1
      • If the adhesive gasket isn't deformed and your lower microphone didn't come with a replacement gasket, you can keep and reuse the gasket. Be aware that you'll lose water and dust resistance.
      • Use tweezers to remove the microphone adhesive gasket from the frame.
      Ask FixBot
    2. iPhone 17 Pro USB-C Port Assembly Replacement, Install the lower microphone: step 62, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Install the lower microphone: step 62, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Install the lower microphone: step 62, image 3 of 3
      • If your replacement lower microphone comes with an adhesive gasket pre-installed, make sure to remove any liners to expose the adhesive.
      • Use tweezers to align the microphone with the frame.
      • Slide the microphone into its recess and press it in place. There should be almost no gap between the microphone and the frame.
      Ask FixBot
    3. iPhone 17 Pro USB-C Port Assembly Replacement: step 63, image 1 of 1
      • Use a hair dryer or an iOpener to heat the lower microphone until it's warm to the touch. This helps strengthen the adhesive bond.
      Ask FixBot
    4. iPhone 17 Pro USB-C Port Assembly Replacement: step 64, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement: step 64, image 2 of 2
      • Install the two lower microphone screws:
      Ask FixBot
    5. iPhone 17 Pro USB-C Port Assembly Replacement: step 65, image 1 of 1
      • Use your finger to press and connect the lower microphone press connector.
      Ask FixBot
    1. iPhone 17 Pro USB-C Port Assembly Replacement, Install the Taptic Engine: step 66, image 1 of 1
      • Place the Taptic Engine upside down on the edge of the iPhone frame.
      • While holding the Taptic Engine with one hand, use your finger to press and connect the Taptic Engine press connector.
      Ask FixBot
    2. iPhone 17 Pro USB-C Port Assembly Replacement: step 67, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 67, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 67, image 3 of 3
      • Flip the Taptic Engine over the frame and align it using its screw holes.
      • The Taptic Engine flex cable should fold neatly between the Taptic Engine and the frame.
      Ask FixBot
    3. iPhone 17 Pro USB-C Port Assembly Replacement: step 68, image 1 of 1
      • Use a standoff screwdriver to install the two 4.0 mm‑long Taptic Engine screws.
      Ask FixBot
    4. iPhone 17 Pro USB-C Port Assembly Replacement, Attach the flex antenna: step 69, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Attach the flex antenna: step 69, image 2 of 2
      • Use your fingers or a spudger to fold the flex antenna down in place.
      Ask FixBot
    5. iPhone 17 Pro USB-C Port Assembly Replacement: step 70, image 1 of 1
      • Use a JIS 00 screwdriver to install the three 2.0 mm‑long flex antenna screws.
      Ask FixBot
    6. iPhone 17 Pro USB-C Port Assembly Replacement, Install the ground clip: step 71, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Install the ground clip: step 71, image 2 of 2
      • Use tweezers to carefully place the ground clip in place.
      • Be sure to orient this clip correctly as shown in the images.
      Ask FixBot
    7. iPhone 17 Pro USB-C Port Assembly Replacement, Install the ground clip: step 72, image 1 of 1
      • Use a JIS 00 screwdriver to install the two 2.0 mm‑long ground clip screws.
      Ask FixBot
    1. iPhone 17 Pro USB-C Port Assembly Replacement, Install the loudspeaker: step 73, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Install the loudspeaker: step 73, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Install the loudspeaker: step 73, image 3 of 3
      • Align the bottom edge of the loudspeaker with the frame and lay it in its recess.
      • Make sure the bottom-right screw tab seats properly against the frame. Gently bend it if it's out of place.
      • Use your finger to press down on the loudspeaker until it clicks in place.
      Ask FixBot
    2. iPhone 17 Pro USB-C Port Assembly Replacement: step 74, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement: step 74, image 2 of 2
      • Use a JIS 00 screwdriver to install the six loudspeaker screws:
      • One 1.5 mm‑long screw attached to the bottom edge of the iPhone frame
      Ask FixBot
    3. iPhone 17 Pro USB-C Port Assembly Replacement, Install the buffer strip: step 75, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Install the buffer strip: step 75, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Install the buffer strip: step 75, image 3 of 3
      • Use your fingers or a spudger to press the buffer strip back onto the top edge of the Taptic Engine.
      Ask FixBot
    1. iPhone 17 Pro USB-C Port Assembly Replacement, Install the battery: step 76, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Install the battery: step 76, image 2 of 2
      • Lay the battery tray in place.
      • Make sure not to trap any cables underneath the tray.
      Ask FixBot
    2. iPhone 17 Pro USB-C Port Assembly Replacement, Install the battery tray screws: step 77, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Install the battery tray screws: step 77, image 2 of 2
      • Use a Torx Plus 4IP screwdriver to install the battery tray screws:
      Ask FixBot
    1. iPhone 17 Pro USB-C Port Assembly Replacement, Clean the frame: step 78, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Clean the frame: step 78, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Clean the frame: step 78, image 3 of 3
      Buy
      • Work around the fragile grounding clips as you clean the frame. If you bend one out of place, gently bend it back with your fingers or tweezers.
      • Use tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
      • Use a spudger to scrape the adhesive residue off the frame.
      • If the adhesive feels stubborn, apply some heat using a hair dryer or heat gun and try again.
      Ask FixBot
    2. iPhone 17 Pro USB-C Port Assembly Replacement: step 79, image 1 of 1
      • Use a lint-free cloth or a coffee filter to wipe in one direction along the perimeter of the frame to clean the adhesive residue.
      • If the residue feels sticky, apply a few drops of isopropyl alcohol to the cloth and wipe again.
      • Take your time doing this. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
      Ask FixBot
    3. iPhone 17 Pro USB-C Port Assembly Replacement, Clean the screen: step 80, image 1 of 1
      Microfiber Cleaning Cloths
      $3.99
      Buy
      • If you're reusing your screen, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
      Ask FixBot
    4. iPhone 17 Pro USB-C Port Assembly Replacement, Orient the replacement adhesive: step 81, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Orient the replacement adhesive: step 81, image 2 of 2
      • Without peeling any liners, lay the adhesive sheet over the frame to determine its proper orientation.
      • Use features such as the camera cutout and notches along the top and bottom edges to visualize how the adhesive will lay in the frame.
      Ask FixBot
    5. iPhone 17 Pro USB-C Port Assembly Replacement, Apply the replacement adhesive: step 82, image 1 of 1
      • Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
      • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
      • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
      Ask FixBot
    6. iPhone 17 Pro USB-C Port Assembly Replacement: step 83, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement: step 83, image 2 of 2
      • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
      • Carefully align the exposed edge of the adhesive strip with the corresponding edge of the iPhone's frame.
      • When it's correctly aligned, gently press the exposed adhesive strip onto the frame.
      Ask FixBot
    7. iPhone 17 Pro USB-C Port Assembly Replacement: step 84, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 84, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 84, image 3 of 3
      • Continue peeling away the liner from the adhesive, gently pressing the adhesive into place.
      • If you've correctly aligned the adhesive, the edges will fall perfectly into place.
      • If your adhesive is slightly misaligned, gently pull the long edges into alignment with the frame.
      • If the adhesive begins to crease or wrinkle, remove it and start over with fresh adhesive.
      • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
      Ask FixBot
    8. iPhone 17 Pro USB-C Port Assembly Replacement: step 85, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement: step 85, image 2 of 2
      • Use a spudger to press the adhesive around the entire perimeter of your iPhone.
      • Work around the fragile grounding clips. If you bend one out of place, gently bend it back with your fingers or tweezers.
      • Don't press too hard, or you'll stretch and deform the adhesive.
      Ask FixBot
    9. iPhone 17 Pro USB-C Port Assembly Replacement: step 86, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 86, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 86, image 3 of 3
      • Use the pull tab to peel off the large front liner from the adhesive. The pull tab is often in a corner of the liner.
      • At this point, you'll still have liners covering the perimeter. Don't remove these liners yet—they prevent the adhesive from accidentally sticking while you reassemble your iPhone.
      Ask FixBot
    10. iPhone 17 Pro USB-C Port Assembly Replacement, Connect the screen: step 87, image 1 of 1
      • Set the iPhone screen next to the frame such that the screen cables can comfortably reach the logic board.
      Ask FixBot
    11. iPhone 17 Pro USB-C Port Assembly Replacement: step 88, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 88, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement: step 88, image 3 of 3
      • Use your finger or the flat end of a spudger to press and connect the two screen connectors onto the logic board.
      • Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    12. iPhone 17 Pro USB-C Port Assembly Replacement, Connect the battery: step 89, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Connect the battery: step 89, image 2 of 2
      • Use your finger or the flat end of a spudger to press and connect the battery connector onto the logic board.
      Ask FixBot
    13. iPhone 17 Pro USB-C Port Assembly Replacement, Test your repair: step 90, image 1 of 1
      • This is a good point to test your repair before sealing up your iPhone. Power on your iPhone and make sure it works as expected. Power it back down and continue reassembly.
      • If your iPhone doesn't turn on, connect it to a power source and try again.
      Ask FixBot
    14. iPhone 17 Pro USB-C Port Assembly Replacement, Install the battery connector cover: step 91, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement, Install the battery connector cover: step 91, image 2 of 2
      • Tuck the top edge of the battery connector cover under the cutout lip.
      • Make sure both tabs are tucked under the lip.
      • Align the cover by its screw hole and lay it in place.
      Ask FixBot
    15. iPhone 17 Pro USB-C Port Assembly Replacement: step 92, image 1 of 1
      • Use a JIS 00 screwdriver to install the 1.2 mm‑long screw to secure the battery connector cover.
      Ask FixBot
    16. iPhone 17 Pro USB-C Port Assembly Replacement, Install the screen connector cover: step 93, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Install the screen connector cover: step 93, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Install the screen connector cover: step 93, image 3 of 3
      • Tuck the left edge of the screen connector cover under the cutout lip.
      Ask FixBot
    17. iPhone 17 Pro USB-C Port Assembly Replacement: step 94, image 1 of 1
      • Use a JIS 00 screwdriver to install the 1.2 mm‑long screw to secure the screen connector cover.
      Ask FixBot
    18. iPhone 17 Pro USB-C Port Assembly Replacement, Remove the final adhesive liners: step 95, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Remove the final adhesive liners: step 95, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Remove the final adhesive liners: step 95, image 3 of 3
      • With one hand hold the screen steady.
      • Use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
      • Make sure nothing touches the exposed adhesive.
      • Check the internals for any stray liners and remove them. There should be no liners remaining.
      Ask FixBot
    19. iPhone 17 Pro USB-C Port Assembly Replacement, Install the screen: step 96, image 1 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Install the screen: step 96, image 2 of 3 iPhone 17 Pro USB-C Port Assembly Replacement, Install the screen: step 96, image 3 of 3
      • Lower the screen onto the frame, beginning with the top edge.
      • If you feel resistance, a perimeter clip may have bent out of place and is being crushed by the frame. Look at the point of resistance and gently straighten any bent clips.
      • Make sure the screen edge isn't pinching any cables.
      • Press along the edges of the iPhone until the screen sits flush against the frame.
      Ask FixBot
    20. iPhone 17 Pro USB-C Port Assembly Replacement: step 97, image 1 of 2 iPhone 17 Pro USB-C Port Assembly Replacement: step 97, image 2 of 2
      • Firmly squeeze around the entire perimeter of the iPhone.
      Ask FixBot
    21. iPhone 17 Pro USB-C Port Assembly Replacement, Apply heat to the perimeter: step 98, image 1 of 1
      • Use a hair dryer or a heat gun to heat the screen perimeter until it's slightly too hot to touch.
      • The heat softens the adhesive and helps create a better bond.
      Ask FixBot
    1. iPhone 17 Pro USB-C Port Assembly Replacement, Install the pentalobe screws: step 99, image 1 of 1
      • Use a P2 pentalobe screwdriver to install the two 7.5 mm‑long screws on either side of the charging port.
      Ask FixBot
Arthur Shi
349,468 Reputation
930 Guides authored
0 Guide Comments
Past 24 Hours: 28
Past 7 Days: 192
Past 30 Days: 780
All Time: 3,497
