Shop the Holiday Gift Guide
iPhone 16 Plus Screen Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
4
Past 30 Days:
27
All Time:
307
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
  • iPhone 16 Plus Screen
    5
Parts
Tools
    1. iPhone 16 Plus Screen Removal, Prepare your phone for disassembly: step 1, image 1 of 2 iPhone 16 Plus Screen Removal, Prepare your phone for disassembly: step 1, image 2 of 2
      • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
      • Unplug any cables from your phone.
      • Hold the power and either volume buttons and slide to power off your phone.
      Ask FixBot
    2. iPhone 16 Plus Screen Removal, Tape over any cracks: step 2, image 1 of 2 iPhone 16 Plus Screen Removal, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    3. iPhone 16 Plus Screen Removal, Mark your opening picks: step 3, image 1 of 3 iPhone 16 Plus Screen Removal, Mark your opening picks: step 3, image 2 of 3 iPhone 16 Plus Screen Removal, Mark your opening picks: step 3, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    4. iPhone 16 Plus Screen Removal, Remove the pentalobe screws: step 4, image 1 of 2 iPhone 16 Plus Screen Removal, Remove the pentalobe screws: step 4, image 2 of 2
      • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the USB-C port.
      Ask FixBot
    1. iPhone 16 Plus Screen Removal, Screen information: step 5, image 1 of 2 iPhone 16 Plus Screen Removal, Screen information: step 5, image 2 of 2
      • For easier screen removal in the next steps, note the following:
      • There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll separate the two.
      • Sometimes the display panel separates from the bezel before you even get a chance to insert a pick. This may be unavoidable depending on the condition of the adhesive.
      Ask FixBot
    2. iPhone 16 Plus Screen Removal, Heat the bottom edge: step 6, image 1 of 2 iPhone 16 Plus Screen Removal, Heat the bottom edge: step 6, image 2 of 2
      • Apply a heated iOpener to the bottom edge of the screen for two minutes.
      • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Ask FixBot
    3. iPhone 16 Plus Screen Removal, Insert an opening pick: step 7, image 1 of 3 iPhone 16 Plus Screen Removal, Insert an opening pick: step 7, image 2 of 3 iPhone 16 Plus Screen Removal, Insert an opening pick: step 7, image 3 of 3
      • Apply a suction handle to the bottom edge of the screen, above the USB-C port.
      • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    4. iPhone 16 Plus Screen Removal, Screen information: step 8, image 1 of 2 iPhone 16 Plus Screen Removal, Screen information: step 8, image 2 of 2
      • As you slice the adhesive securing the screen in the next eight steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
      • Two delicate cables connecting the screen to the phone—one just above the Action button and the other about halfway between the volume down button and the bottom of the phone.
      • Multiple spring contacts around the perimeter of the phone.
      Ask FixBot
    5. iPhone 16 Plus Screen Removal, Separate the bottom adhesive: step 9, image 1 of 3 iPhone 16 Plus Screen Removal, Separate the bottom adhesive: step 9, image 2 of 3 iPhone 16 Plus Screen Removal, Separate the bottom adhesive: step 9, image 3 of 3
      • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
      Ask FixBot
    6. iPhone 16 Plus Screen Removal, Heat the right edge: step 10, image 1 of 2 iPhone 16 Plus Screen Removal, Heat the right edge: step 10, image 2 of 2
      Ask FixBot
    7. iPhone 16 Plus Screen Removal, Separate the right adhesive: step 11, image 1 of 2 iPhone 16 Plus Screen Removal, Separate the right adhesive: step 11, image 2 of 2
      • Slide your opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive and release the metal clip.
      • You'll hear and feel the metal clip release as you pass it.
      Ask FixBot
    8. iPhone 16 Plus Screen Removal, Heat the top edge: step 12, image 1 of 2 iPhone 16 Plus Screen Removal, Heat the top edge: step 12, image 2 of 2
      Ask FixBot
    9. iPhone 16 Plus Screen Removal, Separate the top adhesive: step 13, image 1 of 2 iPhone 16 Plus Screen Removal, Separate the top adhesive: step 13, image 2 of 2
      • Continue sliding your pick around the top right corner and across the top edge to separate the adhesive and release the two metal clips.
      Ask FixBot
    10. iPhone 16 Plus Screen Removal, Heat the left edge: step 14, image 1 of 2 iPhone 16 Plus Screen Removal, Heat the left edge: step 14, image 2 of 2
      Ask FixBot
    11. iPhone 16 Plus Screen Removal, Separate the left adhesive: step 15, image 1 of 2 iPhone 16 Plus Screen Removal, Separate the left adhesive: step 15, image 2 of 2
      • Don't insert your pick deeper than 3 mm to avoid damaging the screen cables and the spring contacts.
      • Slide the opening pick down the left edge of the screen to separate the remaining adhesive and release the last two metal clips.
      Ask FixBot
    12. iPhone 16 Plus Screen Removal, Prop up the screen: step 16, image 1 of 3 iPhone 16 Plus Screen Removal, Prop up the screen: step 16, image 2 of 3 iPhone 16 Plus Screen Removal, Prop up the screen: step 16, image 3 of 3
      • At this point, the screen should be free from the frame. If the screen feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
      • Swing open the screen over the left edge of the phone and support it with a clean, sturdy object.
      Ask FixBot
    13. iPhone 16 Plus Screen Removal, Remove the cover screws: step 17, image 1 of 2 iPhone 16 Plus Screen Removal, Remove the cover screws: step 17, image 2 of 2
      • Use a tri-point Y000 driver to remove the 0.9 mm‑long screw securing the front sensor connector cover.
      • Use a tri-point Y000 driver to remove the 0.9 mm‑long screw securing the screen connector cover.
      Ask FixBot
    14. iPhone 16 Plus Screen Removal, Remove the screen connector covers: step 18, image 1 of 3 iPhone 16 Plus Screen Removal, Remove the screen connector covers: step 18, image 2 of 3 iPhone 16 Plus Screen Removal, Remove the screen connector covers: step 18, image 3 of 3
      • Use tweezers or your fingers to lift the front sensor cover to a 90-degree angle and unhook it from its slot in the logic board.
      • Lift the cover out of its slot and remove it.
      • Repeat this process for the screen connector cover.
      Ask FixBot
    15. iPhone 16 Plus Screen Removal, Disconnect the screen: step 19, image 1 of 3 iPhone 16 Plus Screen Removal, Disconnect the screen: step 19, image 2 of 3 iPhone 16 Plus Screen Removal, Disconnect the screen: step 19, image 3 of 3
      • Use the tip of a spudger to pry up and disconnect the screen press connector.
      • Repeat this process for the front sensor press connector.
      Ask FixBot
    16. iPhone 16 Plus Screen Removal, Remove the screen: step 20, image 1 of 1
      • Lift the screen off of the frame and remove it.
      • Be careful not to damage any of the spring contacts.
      Ask FixBot
    17. iPhone 16 Plus Screen Removal, Remove the ambient light sensor bracket: step 21, image 1 of 3 iPhone 16 Plus Screen Removal, Remove the ambient light sensor bracket: step 21, image 2 of 3 iPhone 16 Plus Screen Removal, Remove the ambient light sensor bracket: step 21, image 3 of 3
      • Use a Phillips screwdriver to remove the 1.3 mm‑long screw securing the ambient light sensor bracket.
      • Use a pair of tweezers or your fingers to lift and remove the ambient light sensor bracket.
      Ask FixBot
    18. iPhone 16 Plus Screen Removal, Pry up the ambient light sensor: step 22, image 1 of 3 iPhone 16 Plus Screen Removal, Pry up the ambient light sensor: step 22, image 2 of 3 iPhone 16 Plus Screen Removal, Pry up the ambient light sensor: step 22, image 3 of 3
      • Use a hair dryer, heat gun, or heated iOpener to soften the adhesive under the ambient light sensor and ambient light sensor cable.
      • Use an opening pick to pry up the ambient light sensor.
      Ask FixBot
    19. iPhone 16 Plus Screen Removal, Peel up the ambient light sensor cable: step 23, image 1 of 2 iPhone 16 Plus Screen Removal, Peel up the ambient light sensor cable: step 23, image 2 of 2
      • Gently slide an opening pick under the ambient light sensor cable, starting near the sensor and moving to the opposite corner.
      • If the adhesive doesn't peel up easily, apply more heat.
      Ask FixBot
    20. iPhone 16 Plus Screen Removal, Remove the ambient light sensor: step 24, image 1 of 3 iPhone 16 Plus Screen Removal, Remove the ambient light sensor: step 24, image 2 of 3 iPhone 16 Plus Screen Removal, Remove the ambient light sensor: step 24, image 3 of 3
      • Continue slowly sliding the opening pick under the ambient light sensor cable until the cable is free from the screen.
      • Use a pair of tweezers to lift the ambient light sensor off of the screen.
      Ask FixBot
To reassemble your phone, follow this guide to reapply adhesive and install your screen.
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Plus Answers Community for help.
Nick Schultz
70,853 Reputation
363 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 307
