Shop the Holiday Gift Guide
iPhone 15 Pro Battery Removal
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
43
All Time:
845
Comments: 44
44 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite only guide to remove the battery in an iPhone 15 Pro.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
    1. iPhone 15 Pro Battery Removal, Prepare your iPhone for disassembly: step 1, image 1 of 2 iPhone 15 Pro Battery Removal, Prepare your iPhone for disassembly: step 1, image 2 of 2
      • Let your phone's battery drain below 25% before starting this repair—a charged lithium‑ion battery may catch fire if damaged.
      • Unplug all cables from your phone.
      • Hold the power and either volume button and slide to power off your phone.
      Ask FixBot
    2. iPhone 15 Pro Battery Removal, Tape over any cracks: step 2, image 1 of 2 iPhone 15 Pro Battery Removal, Tape over any cracks: step 2, image 2 of 2
      • If your screen or back glass is cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
      • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
      Ask FixBot
    1. iPhone 15 Pro Battery Removal, Mark your opening picks: step 3, image 1 of 3 iPhone 15 Pro Battery Removal, Mark your opening picks: step 3, image 2 of 3 iPhone 15 Pro Battery Removal, Mark your opening picks: step 3, image 3 of 3
      • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
      • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
      • You can also mark the other corners of the pick with different measurements.
      • Alternatively, tape a coin to a pick 3 mm from the tip.
      Ask FixBot
    1. iPhone 15 Pro Battery Removal, Remove the pentalobe screws: step 4, image 1 of 2 iPhone 15 Pro Battery Removal, Remove the pentalobe screws: step 4, image 2 of 2
      • Use a P2 pentalobe screwdriver to remove the two 7 mm‑long screws on either side of the charging port.
      Ask FixBot
    1. iPhone 15 Pro Battery Removal, Screen information: step 5, image 1 of 1
      • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
      • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
      • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
      Ask FixBot
    2. iPhone 15 Pro Battery Removal, Heat the bottom edge: step 6, image 1 of 1
      • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
      • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
      Ask FixBot
    3. iPhone 15 Pro Battery Removal, Insert an opening pick: step 7, image 1 of 3 iPhone 15 Pro Battery Removal, Insert an opening pick: step 7, image 2 of 3 iPhone 15 Pro Battery Removal, Insert an opening pick: step 7, image 3 of 3
      • Apply a suction handle to the bottom edge of the screen.
      • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
      • Insert the tip of an opening pick into the gap.
      Ask FixBot
    4. iPhone 15 Pro Battery Removal, Separate the bottom edge adhesive: step 8, image 1 of 3 iPhone 15 Pro Battery Removal, Separate the bottom edge adhesive: step 8, image 2 of 3 iPhone 15 Pro Battery Removal, Separate the bottom edge adhesive: step 8, image 3 of 3
      • Don't insert your opening pick deeper than 3 mm along the bottom edge.
      • Slide your pick back and forth along the bottom edge to separate the adhesive.
      • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
      Ask FixBot
    5. iPhone 15 Pro Battery Removal, Heat the right edge: step 9, image 1 of 1
      • Heat the right edge of the screen until it's hot to the touch.
      Ask FixBot
    6. iPhone 15 Pro Battery Removal, Position the opening pick: step 10, image 1 of 3 iPhone 15 Pro Battery Removal, Position the opening pick: step 10, image 2 of 3 iPhone 15 Pro Battery Removal, Position the opening pick: step 10, image 3 of 3
      • Don't insert your pick deeper than 5 mm along the right edge.
      • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
      • Rotate your pick so the flat edge is under the screen.
      Ask FixBot
    7. iPhone 15 Pro Battery Removal, Release the right clip: step 11, image 1 of 3 iPhone 15 Pro Battery Removal, Release the right clip: step 11, image 2 of 3 iPhone 15 Pro Battery Removal, Release the right clip: step 11, image 3 of 3
      • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
      • Insert a second opening pick to the right of the first pick.
      Ask FixBot
    8. iPhone 15 Pro Battery Removal, Separate the right edge adhesive: step 12, image 1 of 3 iPhone 15 Pro Battery Removal, Separate the right edge adhesive: step 12, image 2 of 3 iPhone 15 Pro Battery Removal, Separate the right edge adhesive: step 12, image 3 of 3
      • Slide the first pick back to the bottom right corner of the screen.
      • Slide the second pick to the top right corner of the screen to separate the adhesive.
      • Leave these picks inserted to prevent the adhesive from resealing.
      Ask FixBot
    9. iPhone 15 Pro Battery Removal, Heat the top edge: step 13, image 1 of 1
      • Heat the top edge of the screen until it's hot to the touch.
      Ask FixBot
    10. iPhone 15 Pro Battery Removal, Separate the top edge adhesive: step 14, image 1 of 3 iPhone 15 Pro Battery Removal, Separate the top edge adhesive: step 14, image 2 of 3 iPhone 15 Pro Battery Removal, Separate the top edge adhesive: step 14, image 3 of 3
      • Don't insert your pick deeper than 3 mm along the top edge.
      • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
      Ask FixBot
    11. iPhone 15 Pro Battery Removal, Heat the left edge: step 15, image 1 of 1
      • Heat the left edge of the screen until it's hot to the touch.
      Ask FixBot
    12. iPhone 15 Pro Battery Removal, Separate the left edge adhesive: step 16, image 1 of 3 iPhone 15 Pro Battery Removal, Separate the left edge adhesive: step 16, image 2 of 3 iPhone 15 Pro Battery Removal, Separate the left edge adhesive: step 16, image 3 of 3
      • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick to the bottom left corner of the screen to separate the adhesive.
      Ask FixBot
    1. iPhone 15 Pro Battery Removal, Prop up the screen: step 17, image 1 of 3 iPhone 15 Pro Battery Removal, Prop up the screen: step 17, image 2 of 3 iPhone 15 Pro Battery Removal, Prop up the screen: step 17, image 3 of 3
      • Place a small box or stack of books to the left of your phone so you can prop up the screen while disconnecting its cables.
      • Swing up the right edge of the screen like the front cover of a book.
      • If the screen feels stuck, go back around the perimeter with an opening pick to separate any remaining adhesive.
      • Prop up the screen so you can access its cables without straining them.
      Ask FixBot
    2. iPhone 15 Pro Battery Removal, Unfasten the logic board cover: step 18, image 1 of 2 iPhone 15 Pro Battery Removal, Unfasten the logic board cover: step 18, image 2 of 2
      • Use a Y000 screwdriver to remove the six screws securing the logic board cover:
      • Four 1.6 mm‑long screws
      • Two 1.3 mm‑long screws
      Ask FixBot
    3. iPhone 15 Pro Battery Removal, Remove the logic board cover: step 19, image 1 of 3 iPhone 15 Pro Battery Removal, Remove the logic board cover: step 19, image 2 of 3 iPhone 15 Pro Battery Removal, Remove the logic board cover: step 19, image 3 of 3
      • Rotate the bottom of the logic board cover counterclockwise and slide the top left corner out from under the ambient light sensor cable to remove it.
      • During reassembly, make sure the top left corner of the cover goes under the ambient light sensor cable.
      Ask FixBot
    4. iPhone 15 Pro Battery Removal, Disconnect the battery: step 20, image 1 of 3 iPhone 15 Pro Battery Removal, Disconnect the battery: step 20, image 2 of 3 iPhone 15 Pro Battery Removal, Disconnect the battery: step 20, image 3 of 3
      • Use the tip of an opening pick to pry up and disconnect the battery press connector from the bottom right corner of the logic board.
      • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
      Ask FixBot
    5. iPhone 15 Pro Battery Removal, Disconnect the screen: step 21, image 1 of 2 iPhone 15 Pro Battery Removal, Disconnect the screen: step 21, image 2 of 2
      • Use the tip of an opening pick to pry up and disconnect the screen cable from the center of the logic board.
      Ask FixBot
    6. iPhone 15 Pro Battery Removal, Disconnect the ambient light sensor: step 22, image 1 of 2 iPhone 15 Pro Battery Removal, Disconnect the ambient light sensor: step 22, image 2 of 2
      • Gently slide the tip of an opening pick under the ambient light sensor cable near the top left corner of the logic board.
      • Lift the cable to disconnect it.
      Ask FixBot
    7. iPhone 15 Pro Battery Removal, Remove the screen: step 23, image 1 of 2 iPhone 15 Pro Battery Removal, Remove the screen: step 23, image 2 of 2
      • Remove the screen.
      • During reassembly, follow this guide to apply new adhesive and install your screen.
      • Be careful not to damage any of the spring contacts as you clean the frame.
      Ask FixBot
    1. iPhone 15 Pro Battery Removal, Disconnect the Taptic Engine: step 24, image 1 of 2 iPhone 15 Pro Battery Removal, Disconnect the Taptic Engine: step 24, image 2 of 2
      • Use the point of a spudger to pry up and disconnect the Taptic Engine press connector.
      Ask FixBot
    2. iPhone 15 Pro Battery Removal, Unfasten the Taptic Engine: step 25, image 1 of 2 iPhone 15 Pro Battery Removal, Unfasten the Taptic Engine: step 25, image 2 of 2
      • Use a Phillips #000 screwdriver to remove the two 2 mm‑long screws securing the Taptic Engine.
      Ask FixBot
    3. iPhone 15 Pro Battery Removal, Remove the Taptic Engine: step 26, image 1 of 1
      • Remove the Taptic Engine.
      Ask FixBot
    1. iPhone 15 Pro Battery Removal, Adhesive information: step 27, image 1 of 1
      • Three sections of stretch release adhesive secure the battery to the frame—two along the bottom and one on top.
      • Each strip has a black pull tab at its end, which is lightly adhered to the edge of the battery.
      • In the following steps, you'll pull each tab out from underneath the battery.
      • The strips loosen when stretched, but might break off before you can fully remove them, especially the top edge strip. If any break, don't worry! Keep reading for an alternate way to remove the battery.
      Ask FixBot
    2. iPhone 15 Pro Battery Removal, Separate the pull tabs: step 28, image 1 of 3 iPhone 15 Pro Battery Removal, Separate the pull tabs: step 28, image 2 of 3 iPhone 15 Pro Battery Removal, Separate the pull tabs: step 28, image 3 of 3
      Tool used on this step:
      Buy
      • Don't puncture or dent the battery with your tool, as it can leak dangerous chemicals or catch fire if damaged.
      • Use the tip of an opening pick to gently unstick an edge of an adhesive pull tab from the edge of the battery.
      • Use blunt nose tweezers to grip the edge of the pull tab and pull it completely off the edge of the battery.
      • Repeat for the other two pull tabs.
      Ask FixBot
    3. iPhone 15 Pro Battery Removal, Remove the stretch release adhesive: step 29, image 1 of 3 iPhone 15 Pro Battery Removal, Remove the stretch release adhesive: step 29, image 2 of 3 iPhone 15 Pro Battery Removal, Remove the stretch release adhesive: step 29, image 3 of 3
      • Pull one of the pull tabs out from under the battery until you can grip it with your fingers or wrap it around your tool.
      • Hold the phone steady using the edges of the frame—don't press down on the battery.
      • Pull the strip slowly, evenly, and at a low angle without dragging on other components.
      • Continue pulling, re-gripping or wrapping it around your tool as you go, until the strip fully releases from under the battery.
      • If the strip breaks off, try to retrieve it. If you can't grip it from under the battery, move on to the next step.
      • Repeat this step for the other two strips.
      Ask FixBot
    4. iPhone 15 Pro Battery Removal, Alternate method to remove the battery: step 30, image 1 of 2 iPhone 15 Pro Battery Removal, Alternate method to remove the battery: step 30, image 2 of 2
      • If you removed all three stretch release adhesive strips, congratulations—you can now remove the battery! If not, follow the next two steps to separate the adhesive with isopropyl alcohol and a plastic card.
      • If the top strip remains, prop up the top edge of the phone.
      • If either of the bottom strips remain, prop up the left edge of the phone (the side with the volume buttons).
      • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the elevated edge of the battery.
      • Wait one minute for the isopropyl alcohol to flow under the battery and soften the adhesive.
      Ask FixBot
    5. iPhone 15 Pro Battery Removal, Pry up the battery: step 31, image 1 of 3 iPhone 15 Pro Battery Removal, Pry up the battery: step 31, image 2 of 3 iPhone 15 Pro Battery Removal, Pry up the battery: step 31, image 3 of 3
      Plastic Cards
      $2.99
      Buy
      • Don't bend or crease your battery. If the adhesive feels stubborn, apply a few more drops of isopropyl alcohol and try again.
      • Insert the short edge of a plastic card between the bottom edge of the battery and the frame.
      • Be careful not to scrape the frame underneath the battery—the wireless charging coil is exposed near the center.
      • Gently pry up the battery until the adhesive fully separates.
      • Depending on how strong your adhesive is, this may take some time. Allow up to a minute of constant pressure for the adhesive to loosen.
      Ask FixBot
    6. iPhone 15 Pro Battery Removal, Remove the battery: step 32, image 1 of 2 iPhone 15 Pro Battery Removal, Remove the battery: step 32, image 2 of 2
      • Remove the battery.
      Ask FixBot
Congratulations on replacing the battery!
Depending on the replacement part, you may be able to pair it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings → General →About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
For optimal performance, calibrate your newly installed battery after completing this guide.
Spencer Day
210,422 Reputation
1,265 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 43
All Time: 845
