Shop the Holiday Gift Guide
iPhone 14 Plus Screen prereq
View statistics:
Past 24 Hours:
3
Past 7 Days:
9
Past 30 Days:
33
All Time:
357
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
This is a prerequisite-only guide! This guide is part of another procedure and isn't meant to be used alone.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
  • iPhone 14 Plus Screen
    4.7
Parts
Tools
    1. iPhone 14 Plus Screen prereq, Tape over any cracks: step 1, image 1 of 3 iPhone 14 Plus Screen prereq, Tape over any cracks: step 1, image 2 of 3 iPhone 14 Plus Screen prereq, Tape over any cracks: step 1, image 3 of 3
      • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
      • If all else fails, you can superglue the suction cup to the screen.
      Ask FixBot
    2. iPhone 14 Plus Screen prereq, Screen information: step 2, image 1 of 3 iPhone 14 Plus Screen prereq, Screen information: step 2, image 2 of 3 iPhone 14 Plus Screen prereq, Screen information: step 2, image 3 of 3
      • For easier screen removal in the next steps, note the following:
      • There's a plastic bezel on the underside of the screen. Your opening pick will go underneath this bezel.
      • There's a seam between the plastic bezel and the display panel. Don't insert your pick here or you'll separate the two.
      • Sometimes the display panel separates from the bezel before you even get a chance to insert a pick. This may be unavoidable depending on the condition of the adhesive.
      Ask FixBot
    3. iPhone 14 Plus Screen prereq, Heat the bottom edge: step 3, image 1 of 1
      • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone until the screen is slightly too hot to touch.
      • Never leave your heat gun in one spot for an extended period of time.
      Ask FixBot
    4. iPhone 14 Plus Screen prereq, Insert an opening pick: step 4, image 1 of 3 iPhone 14 Plus Screen prereq, Insert an opening pick: step 4, image 2 of 3 iPhone 14 Plus Screen prereq, Insert an opening pick: step 4, image 3 of 3
      • Apply a suction handle to the bottom edge of the phone, while avoiding the very edge of the glass.
      • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
      • Insert an opening pick into the gap under the screen's plastic bezel.
      • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
      Ask FixBot
    5. iPhone 14 Plus Screen prereq, Heat the right edge: step 5, image 1 of 2 iPhone 14 Plus Screen prereq, Heat the right edge: step 5, image 2 of 2
      • Heat the right edge of the iPhone (the edge with the power button) until the screen is slightly too hot to touch.
      Ask FixBot
    6. iPhone 14 Plus Screen prereq, Separate the right adhesive: step 6, image 1 of 3 iPhone 14 Plus Screen prereq, Separate the right adhesive: step 6, image 2 of 3 iPhone 14 Plus Screen prereq, Separate the right adhesive: step 6, image 3 of 3
      • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
      • Continue sliding up the right edge of the iPhone until you reach the top right corner.
      • Don't insert your pick more than 3 mm, as you may damage internal components.
      • Leave the pick in the top right corner before continuing.
      Ask FixBot
    7. iPhone 14 Plus Screen prereq, Heat the top edge: step 7, image 1 of 1
      • Heat the top edge of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    8. iPhone 14 Plus Screen prereq, Slice the top edge adhesive: step 8, image 1 of 3 iPhone 14 Plus Screen prereq, Slice the top edge adhesive: step 8, image 2 of 3 iPhone 14 Plus Screen prereq, Slice the top edge adhesive: step 8, image 3 of 3
      • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
      • Don't insert your pick more than 3 mm, as you may damage the top sensors.
      • Leave the pick in the top left corner before continuing.
      Ask FixBot
    9. iPhone 14 Plus Screen prereq, Heat the left edge: step 9, image 1 of 2 iPhone 14 Plus Screen prereq, Heat the left edge: step 9, image 2 of 2
      • Heat the left edge of the iPhone until the screen is slightly too hot to touch.
      Ask FixBot
    10. iPhone 14 Plus Screen prereq, Separate the left adhesive: step 10, image 1 of 3 iPhone 14 Plus Screen prereq, Separate the left adhesive: step 10, image 2 of 3 iPhone 14 Plus Screen prereq, Separate the left adhesive: step 10, image 3 of 3
      • There are delicate cables along the left edge of your iPhone. Don't insert your pick deeper than 2 mm here, as you may damage the cables.
      • Rotate your pick around the top left corner of the screen.
      • Slide your pick to the bottom left corner of the screen to separate the adhesive.
      • If you're having trouble separating the adhesive, reheat the left edge.
      Ask FixBot
    11. iPhone 14 Plus Screen prereq, Open the iPhone: step 11, image 1 of 3 iPhone 14 Plus Screen prereq, Open the iPhone: step 11, image 2 of 3 iPhone 14 Plus Screen prereq, Open the iPhone: step 11, image 3 of 3
      • Remove your suction handle from the screen.
      • Rotate your iPhone so the right edge faces you.
      • Open your iPhone by swinging the screen up from the right side, like the front cover of a book.
      • Lean the screen against something to keep it propped up while you're working on the phone.
      • If you don't have anything at hand to lean the screen against, your suction handle can do the trick.
      • During reassembly, lay the screen in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the screen down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the screen and make sure they aren't bent.
      Ask FixBot
    12. iPhone 14 Plus Screen prereq, Unfasten the display connector bracket screw: step 12, image 1 of 2 iPhone 14 Plus Screen prereq, Unfasten the display connector bracket screw: step 12, image 2 of 2
      Tool used on this step:
      Magnetic Project Mat
      $19.95
      Buy
      • Use a Y000 screwdriver to remove the 0.8 mm-long screw securing the display connector bracket.
      • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
      • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the screen in place. Be sure to power your iPhone back down completely before you continue working.
      Ask FixBot
    13. iPhone 14 Plus Screen prereq, Remove the display connector bracket: step 13, image 1 of 3 iPhone 14 Plus Screen prereq, Remove the display connector bracket: step 13, image 2 of 3 iPhone 14 Plus Screen prereq, Remove the display connector bracket: step 13, image 3 of 3
      Buy
      • Grasp the screw hole end of the connector bracket with a pair of tweezers.
      • Lift the bracket slightly to loosen the latch on the other edge.
      • Remove the display connector bracket.
      • During reassembly, make sure the bracket latches properly.
      Ask FixBot
    14. iPhone 14 Plus Screen prereq, Disconnect the display connector: step 14, image 1 of 2 iPhone 14 Plus Screen prereq, Disconnect the display connector: step 14, image 2 of 2
      • Use the pointed end of a spudger to disconnect the display cable by prying the connector straight up from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Ask FixBot
    15. iPhone 14 Plus Screen prereq, Unfasten the front sensor connector bracket: step 15, image 1 of 2 iPhone 14 Plus Screen prereq, Unfasten the front sensor connector bracket: step 15, image 2 of 2
      • Use a Y000 screwdriver to remove the 1 mm-long screw securing the front sensor connector bracket.
      Ask FixBot
    16. iPhone 14 Plus Screen prereq, Remove the front sensor connector bracket: step 16, image 1 of 3 iPhone 14 Plus Screen prereq, Remove the front sensor connector bracket: step 16, image 2 of 3 iPhone 14 Plus Screen prereq, Remove the front sensor connector bracket: step 16, image 3 of 3
      • Remove the front sensor connector bracket.
      Ask FixBot
    17. iPhone 14 Plus Screen prereq, Disconnect the front sensor connector cable: step 17, image 1 of 2 iPhone 14 Plus Screen prereq, Disconnect the front sensor connector cable: step 17, image 2 of 2
      • Use the pointed end of a spudger to disconnect the front sensor cable by prying the connector straight up from its socket.
      Ask FixBot
    18. iPhone 14 Plus Screen prereq, Remove the screen: step 18, image 1 of 2 iPhone 14 Plus Screen prereq, Remove the screen: step 18, image 2 of 2
      • Remove the screen.
      • Apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
      • During reassembly, pause here if you wish to replace the screen adhesives.
      Ask FixBot
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the frame and place the screen back in its original position.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Author
with
Dominik Schnabelrauch
267,747 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 33
All Time: 357
