iPhone 12 Front-Facing Cameras Replacement
  1. iPhone 12 Front-Facing Cameras Replacement, Remove the pentalobe screws: step 1, image 1 of 1
    • Caution: Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.75 mm long pentalobe P2 screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 12 Front-Facing Cameras Replacement, Tape over any cracks: step 2, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Tape over any cracks: step 2, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Tape over any cracks: step 2, image 3 of 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  3. iPhone 12 Front-Facing Cameras Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Anti-Clamp instructions: step 3, image 3 of 3
    Tool used on this step:
    Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 12 Front-Facing Cameras Replacement: step 4, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement: step 4, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement: step 4, image 3 of 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPhone 12 Front-Facing Cameras Replacement: step 5, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement: step 5, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement: step 5, image 3 of 3
    • Support your iPhone on something sturdy such as a hardcover book so it rests hands-free and parallel to the ground; this makes it easier to work with in the following steps.
    • Use a hair dryer to heat along the bottom edge of the iPhone. The screen should feel slightly too hot to touch.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen's plastic bezel when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone 12 Front-Facing Cameras Replacement, Heat the bottom edge: step 6, image 1 of 1
    • Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
    • Never leave your hair dryer in one spot for an extended period of time.
  7. iPhone 12 Front-Facing Cameras Replacement, Apply a suction cup: step 7, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Apply a suction cup: step 7, image 2 of 2
    • If you're using a single suction handle, apply it to the bottom edge of the phone, while avoiding the very edge of the glass.
  8. iPhone 12 Front-Facing Cameras Replacement, Lift the screen slightly: step 8, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Lift the screen slightly: step 8, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Lift the screen slightly: step 8, image 3 of 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the screen and the frame.
    • Insert an opening pick into the gap under the screen's plastic bezel.
    • The watertight adhesive holding the screen in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
  9. iPhone 12 Front-Facing Cameras Replacement, Heat the right edge: step 9, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Heat the right edge: step 9, image 2 of 2
    • Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the screen is slightly too hot to touch.
  10. iPhone 12 Front-Facing Cameras Replacement, Separate the right adhesive: step 10, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Separate the right adhesive: step 10, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Separate the right adhesive: step 10, image 3 of 3
    • Slide the opening pick around the bottom right corner of the iPhone to separate its adhesive.
    • Continue sliding up the right edge of the iPhone until you reach the top right corner.
    • Don't insert your pick more than 3 mm, as you may damage internal components.
    • Leave the pick in the top right corner before continuing.
  11. iPhone 12 Front-Facing Cameras Replacement, Heat the top edge: step 11, image 1 of 1
    • Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  12. iPhone 12 Front-Facing Cameras Replacement, Separate the top adhesive: step 12, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Separate the top adhesive: step 12, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Separate the top adhesive: step 12, image 3 of 3
    • Slide the opening pick around the top right corner of the iPhone to separate the top adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the top sensors.
    • Leave the pick in the top left corner before continuing.
  13. iPhone 12 Front-Facing Cameras Replacement, Heat the left edge: step 13, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Heat the left edge: step 13, image 2 of 2
    • Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the screen is slightly too hot to touch.
  14. iPhone 12 Front-Facing Cameras Replacement, Screen information: step 14, image 1 of 1
    • There are delicate cables along the left edge of your iPhone. Don't insert your pick here, as you may damage the cables.
  15. iPhone 12 Front-Facing Cameras Replacement, Separate the left adhesive: step 15, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Separate the left adhesive: step 15, image 2 of 2
    • Insert a second opening pick in the bottom left corner of the iPhone.
    • Twist both picks simultaneously until the left edge clips release.
    • Apply the twisting force gradually.
    • If you're having trouble separating the adhesive, reheat the left edge.
  16. iPhone 12 Front-Facing Cameras Replacement, Open the iPhone: step 16, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Open the iPhone: step 16, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Open the iPhone: step 16, image 3 of 3
    • Rotate your iPhone so the right edge faces you.
    • Open the iPhone by swinging the display up from the right side, like the front cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    • During reassembly, lay the display in position, align the clips along the top edge, and carefully press the top edge into place before snapping the rest of the display down. If it doesn't click easily into place, check the condition of the clips around the perimeter of the display and make sure they aren't bent.
  17. iPhone 12 Front-Facing Cameras Replacement, Unscrew the battery and display connector cover: step 17, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Remove two 1.1 mm long Y000 screws securing the battery and display connector cover.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
    • During reassembly, this is a good point to power on your iPhone and test all functions before you seal the display in place. Be sure to power your iPhone back down completely before you continue working.
  18. iPhone 12 Front-Facing Cameras Replacement, Disconnect the battery: step 19, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Disconnect the battery: step 19, image 2 of 2
    • Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
    • Try not to damage the black silicone seal surrounding this and other board connections. These seals provide extra protection against water and dust intrusion.
    • Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
  19. iPhone 12 Front-Facing Cameras Replacement, Disconnect the display cable: step 20, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Disconnect the display cable: step 20, image 2 of 2
    • Use a spudger or a fingernail to disconnect the display cable connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  20. iPhone 12 Front-Facing Cameras Replacement, Disconnect the digitizer cable: step 21, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Disconnect the digitizer cable: step 21, image 2 of 2
    • Use a spudger or a fingernail to disconnect the digitizer cable connector.
    • If any part of your screen doesn't respond to touch after your repair, disconnect the battery and then re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  21. iPhone 12 Front-Facing Cameras Replacement, Unscrew the front sensor connector cover: step 22, image 1 of 1
    • Use a Y000 driver to remove four screws securing the front sensor connector cover.
    • Three 1.1 mm long screws
    • One 1.4 mm long screw
  22. iPhone 12 Front-Facing Cameras Replacement, Remove the front sensor connector cover: step 23, image 1 of 3 iPhone 12 Front-Facing Cameras Replacement, Remove the front sensor connector cover: step 23, image 2 of 3 iPhone 12 Front-Facing Cameras Replacement, Remove the front sensor connector cover: step 23, image 3 of 3
    • Swing the cover up from the left until the small clip on the right unhooks.
    • Remove the cover.
    • During reassembly, insert the clip on the right edge into its slot first, then hinge the rest of the cover into place.
  23. iPhone 12 Front-Facing Cameras Replacement, Disconnect the front sensors: step 24, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Disconnect the front sensors: step 24, image 2 of 2
    • Use a spudger or a fingernail to disconnect the front sensor assembly cable connector.
  24. iPhone 12 Front-Facing Cameras Replacement, Remove the display assembly: step 25, image 1 of 1
  25. iPhone 12 Front-Facing Cameras Replacement, Unscrew the front-facing camera assembly: step 26, image 1 of 1
    • Use a Y000 driver to remove the 1 mm long screw securing the front-facing camera assembly.
  26. iPhone 12 Front-Facing Cameras Replacement, Remove the front-facing camera bracket: step 27, image 1 of 1
    • Lift up and remove the front-facing camera bracket.
  27. iPhone 12 Front-Facing Cameras Replacement, Disconnect the front-facing camera assembly: step 28, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement, Disconnect the front-facing camera assembly: step 28, image 2 of 2
    • Use a spudger or a fingernail to disconnect the Face ID dot projector cable from its socket on the logic board.
  28. iPhone 12 Front-Facing Cameras Replacement: step 29, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement: step 29, image 2 of 2
    • Use a spudger or a fingernail to disconnect the Face ID sensor cable from its socket on the logic board.
  29. iPhone 12 Front-Facing Cameras Replacement: step 30, image 1 of 2 iPhone 12 Front-Facing Cameras Replacement: step 30, image 2 of 2
    • Gently push the Face ID cable connectors away from the logic board to access the selfie cam connector underneath.
    • Disconnect the selfie camera by prying its connector straight up.
  30. iPhone 12 Front-Facing Cameras Replacement, Remove the front-facing camera assembly: step 31, image 1 of 1
    • Remove the front-facing camera assembly.
Adam O'Camb
197,111 Reputation
416 Guides authored
Past 24 Hours: 23
Past 7 Days: 183
Past 30 Days: 763
All Time: 22,056
