iPad Pro 9.7" Battery Disconnect
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad Pro 9.7" Battery Disconnect, Disconnect the battery: step 1, image 1 of 1
    • Use a Phillips screwdriver to remove the eleven 1.3 mm screws securing the EMI shield.
  2. iPad Pro 9.7" Battery Disconnect: step 2, image 1 of 1
    • Apply a heated iOpener to the EMI shield on the logic board for one minute.
  3. iPad Pro 9.7" Battery Disconnect: step 3, image 1 of 3 iPad Pro 9.7" Battery Disconnect: step 3, image 2 of 3 iPad Pro 9.7" Battery Disconnect: step 3, image 3 of 3
    • Lift the logic board EMI shield, starting at the edge nearest the top of the iPad.
    • Slowly peel the EMI shield up from the logic board.
    • This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when reinstalled and screwed down.
    • Remove the logic board EMI shield.
  4. iPad Pro 9.7" Battery Disconnect: step 4, image 1 of 1
    • Use a Phillips driver to remove the screw securing the battery connector.
  5. iPad Pro 9.7" Battery Disconnect: step 5, image 1 of 3 iPad Pro 9.7" Battery Disconnect: step 5, image 2 of 3 iPad Pro 9.7" Battery Disconnect: step 5, image 3 of 3
    • If the EMI shield has any sharp protrusions after removal, you should flatten them before reinstalling the shield.
    • Squeeze the sharp protrusion with a pair of pliers to flatten it.
    • Repeat the process for all sharp protrusions along the edges of the EMI shield.
Arthur Shi
255,191 Reputation
529 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,520 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 136
