Shop the Holiday Gift Guide
iPad Pro 9.7" Battery Disconnect
View statistics:
Past 24 Hours:
Past 7 Days:
5
Past 30 Days:
20
All Time:
474
Comments: 4
4 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
Prerequisite only guide. Shows how to disconnect the battery for the iPad Pro 9.7".
Tools
    1. iPad Pro 9.7" Battery Disconnect, Disconnect the battery: step 1, image 1 of 1
      • Use a Phillips screwdriver to remove the eleven 1.3 mm screws securing the EMI shield.
      Ask FixBot
    2. iPad Pro 9.7" Battery Disconnect: step 2, image 1 of 1
      • Apply a heated iOpener to the EMI shield on the logic board for one minute.
      Ask FixBot
    3. iPad Pro 9.7" Battery Disconnect: step 3, image 1 of 3 iPad Pro 9.7" Battery Disconnect: step 3, image 2 of 3 iPad Pro 9.7" Battery Disconnect: step 3, image 3 of 3
      • Lift the logic board EMI shield, starting at the edge nearest the top of the iPad.
      • Slowly peel the EMI shield up from the logic board.
      • This takes a bit of force due to the many tiny clips securing the shield, and the shield may deform slightly. That's okay—try to keep the deformation to a minimum, and it will lay flat when reinstalled and screwed down.
      • Remove the logic board EMI shield.
      Ask FixBot
    4. iPad Pro 9.7" Battery Disconnect: step 4, image 1 of 1
      • Use a Phillips driver to remove the 1.7 mm-long screw securing the battery connector.
      Ask FixBot
    5. iPad Pro 9.7" Battery Disconnect: step 5, image 1 of 3 iPad Pro 9.7" Battery Disconnect: step 5, image 2 of 3 iPad Pro 9.7" Battery Disconnect: step 5, image 3 of 3
      • If the EMI shield has any sharp protrusions after removal, you should flatten them before reinstalling the shield.
      • Squeeze the sharp protrusion with a pair of pliers to flatten it.
      • Repeat the process for all sharp protrusions along the edges of the EMI shield.
      Ask FixBot
Author
with
Arthur Shi
353,987 Reputation
938 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,954 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 20
All Time: 474
