SteelSeries Stratus Duo Charging Port Replacement
  1. SteelSeries Stratus Duo Charging Port Replacement, Remove the sticker: step 1, image 1 of 2 SteelSeries Stratus Duo Charging Port Replacement, Remove the sticker: step 1, image 2 of 2
    • Use your fingers to remove the sticker located on the back cover of the Stratus Duo.
    • If you have trouble removing the sticker, heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath. You can also use a hair dryer to soften the adhesive.
  2. SteelSeries Stratus Duo Charging Port Replacement, Unscrew the back cover: step 2, image 1 of 1
    • Use a Y0 Tri-point screwdriver to remove the five 9.3 mm-long screws securing the back cover.
  3. SteelSeries Stratus Duo Charging Port Replacement, Reposition the back cover assembly: step 3, image 1 of 3 SteelSeries Stratus Duo Charging Port Replacement, Reposition the back cover assembly: step 3, image 2 of 3 SteelSeries Stratus Duo Charging Port Replacement, Reposition the back cover assembly: step 3, image 3 of 3
    • Don't try to remove the back cover assembly all the way yet, as it's still connected to the mainboard.
    • Carefully lift the back cover assembly away from the frame and move it downward to uncover the battery cable and the interconnect cable at the top of the motherboard.
  4. SteelSeries Stratus Duo Charging Port Replacement, Disconnect the interconnect cable: step 4, image 1 of 3 SteelSeries Stratus Duo Charging Port Replacement, Disconnect the interconnect cable: step 4, image 2 of 3 SteelSeries Stratus Duo Charging Port Replacement, Disconnect the interconnect cable: step 4, image 3 of 3
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
  5. SteelSeries Stratus Duo Charging Port Replacement: step 5, image 1 of 2 SteelSeries Stratus Duo Charging Port Replacement: step 5, image 2 of 2
    • Use a pair of blunt nosed tweezers or your fingers to pull the cable out of the socket.
  6. SteelSeries Stratus Duo Charging Port Replacement, Disconnect the battery cable: step 6, image 1 of 3 SteelSeries Stratus Duo Charging Port Replacement, Disconnect the battery cable: step 6, image 2 of 3 SteelSeries Stratus Duo Charging Port Replacement, Disconnect the battery cable: step 6, image 3 of 3
    • Use a pair of blunt nose tweezers to grab and lift the connector away from the motherboard.
  7. SteelSeries Stratus Duo Charging Port Replacement, Remove the back cover assembly: step 7, image 1 of 1
    • Remove the back cover assembly.
  8. SteelSeries Stratus Duo Charging Port Replacement, Pry up the battery: step 8, image 1 of 2 SteelSeries Stratus Duo Charging Port Replacement, Pry up the battery: step 8, image 2 of 2
    • The battery is held in place by mild adhesive.
    • Insert the long edge of an opening pick into the gap between the battery and the back cover assembly.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Use the opening pick to carefully pry up the battery and separate the adhesive.
  9. SteelSeries Stratus Duo Charging Port Replacement, Remove the battery: step 9, image 1 of 3 SteelSeries Stratus Duo Charging Port Replacement, Remove the battery: step 9, image 2 of 3 SteelSeries Stratus Duo Charging Port Replacement, Remove the battery: step 9, image 3 of 3
    • Grab the battery with your fingers and lift it out of its recess to remove it.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • During reassembly make sure to align the battery and the back cover correctly.
    • During reassembly, follow this guide if you are using a pre-cut adhesive card.
  10. SteelSeries Stratus Duo Charging Port Replacement, Unscrew the plastic bracket: step 10, image 1 of 1
    • Use a Phillips screwdriver to remove the two 7.2 mm-long screws securing the plastic bracket that holds the charging port and the Bluetooth/power buttons in place.
  11. SteelSeries Stratus Duo Charging Port Replacement, Remove the plastic bracket: step 11, image 1 of 3 SteelSeries Stratus Duo Charging Port Replacement, Remove the plastic bracket: step 11, image 2 of 3 SteelSeries Stratus Duo Charging Port Replacement, Remove the plastic bracket: step 11, image 3 of 3
    • Use your fingers to push the plastic bracket downwards into the recess of the battery to loosen it.
    • Remove the plastic bracket.
  12. SteelSeries Stratus Duo Charging Port Replacement, Remove the charging port: step 12, image 1 of 1
    • Remove the charging port.
Repair didn’t go as planned? Ask our Answers community for help.
Adriana Zwink
43,377 Reputation
167 Guides authored
iFixit Member of iFixit
Community
136 Members
15,116 Guides authored
One Comment
Where can i get the replacement board? Stratus is not responding to my messages.
ryan olson - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 307
