Shop the Holiday Gift Guide
Screen Removal
View statistics:
Past 24 Hours:
0
Past 7 Days:
5
Past 30 Days:
20
All Time:
222
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 - 2 hours
Difficulty: Moderate
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Screen Removal
Introduction
Go to step 1 ↓
Use this guide to remove the screen in your iPad Pro 12.9" 5th Gen.
For your safety, discharge the battery below 25% before disassembling your iPad. This reduces the risk of fire if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Parts
Tools
    1. Screen Removal, Unfasten the display brackets: step 1, image 1 of 1
      • Use a Phillips screwdriver to remove the seven screws securing the top and bottom display brackets:
      • Four 1.1 mm-long screws
      • Two 2.0 mm-long screws
      • One 1.0 mm-long screw
      Ask FixBot
    2. Screen Removal, Remove the display brackets: step 2, image 1 of 3 Screen Removal, Remove the display brackets: step 2, image 2 of 3 Screen Removal, Remove the display brackets: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Use tweezers, or your fingers, to remove the top and bottom display brackets.
      Ask FixBot
    3. Screen Removal, Disconnect the bottom display cables: step 3, image 1 of 3 Screen Removal, Disconnect the bottom display cables: step 3, image 2 of 3 Screen Removal, Disconnect the bottom display cables: step 3, image 3 of 3
      • Use a spudger to pry up and disconnect the two bottom display cable press connectors.
      Ask FixBot
    4. Screen Removal, Disconnect the top display cables: step 4, image 1 of 3 Screen Removal, Disconnect the top display cables: step 4, image 2 of 3 Screen Removal, Disconnect the top display cables: step 4, image 3 of 3
      • Use a spudger to pry up and disconnect the two top display cable press connectors.
      Ask FixBot
    5. Screen Removal, Remove the screen: step 5, image 1 of 3 Screen Removal, Remove the screen: step 5, image 2 of 3 Screen Removal, Remove the screen: step 5, image 3 of 3
      • Remove the screen.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 12.9" 5th Generation Answers community for help.
Author
with
Alex Diaz-Kokaisl
252,776 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 20
All Time: 222
